PTO seal leaking
/ PTO seal leaking #1
3gunr
wentzville mo
mahindra 2538 mahindra 2810 cub cadet 7260 massey 255
My mahindra 2538 pto seal has a slight leak, I have the new seal and am wondering if i should use some type of gasket sealer on the gasket or not
/ PTO seal leaking #2
I usually put a little oil or grease but mainly use whatever fluid it it restraining on the lip when installing seals.
/ PTO seal leaking #3
I only grease both sides of gasket, and inside of seal.
/ PTO seal leaking #4
Usually they don't leak unless the fluid in the gearbox is too high. It needs to be below the seal lip, or if the outboard bearing has excessive radial play.
/ PTO seal leaking
the hyd fluid sightglass is higher than the pto seal , so i assume the fluid is also so not sure what you mean by fluid being to high ?
/ PTO seal leaking
The sightglass is even with the top of the pto shaft The level fluid line is just above the shaft , So the lower 2/3 of the seal has fluid on it,
/ PTO seal leaking #8
I usually go by how the original gasket was installed. If it had some form of sealant I use some on the replacement. If not install it without.
2016 John Deere 1775NT Planter (A63109)
2016 John Deere...
2006 TerraGator 8104 (A63118)
2006 TerraGator...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
2026 Steel Pines Cargo 7x16 Enclosed Trailer, VIN# 7FWBE1622T1037829 (A61166)
2026 Steel Pines...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
