PTO seal leaking
   / PTO seal leaking #1
3gunr
Veteran Member
wentzville mo
mahindra 2538 mahindra 2810 cub cadet 7260 massey 255
My mahindra 2538 pto seal has a slight leak, I have the new seal and am wondering if i should use some type of gasket sealer on the gasket or not
   / PTO seal leaking #2
I usually put a little oil or grease but mainly use whatever fluid it it restraining on the lip when installing seals.
   / PTO seal leaking #3
I only grease both sides of gasket, and inside of seal.
   / PTO seal leaking #4
Usually they don't leak unless the fluid in the gearbox is too high. It needs to be below the seal lip, or if the outboard bearing has excessive radial play.
   / PTO seal leaking
the hyd fluid sightglass is higher than the pto seal , so i assume the fluid is also so not sure what you mean by fluid being to high ?
   / PTO seal leaking
The sightglass is even with the top of the pto shaft The level fluid line is just above the shaft , So the lower 2/3 of the seal has fluid on it,
   / PTO seal leaking #8
I usually go by how the original gasket was installed. If it had some form of sealant I use some on the replacement. If not install it without.
2019 Allmand Light tower (A49461)
2019 Allmand Light...
Honda 2225CW Gas Blower / Vac (A50860)
Honda 2225CW Gas...
20 ft. Shipping Container (A50860)
20 ft. Shipping...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A50854)
2021 ALLMAND BROS...
