PTO rotation
   / PTO rotation #1
hagrant
Woodstock, NB Canada
454 foton
Is it normal for the PTO stub to rotate slightly without being physically engaged? I notice it is turning very slowly and it is not engaged.
   / PTO rotation #2
In some transmissions the fluid flow can cause the shaft to rotate.
Depends on your machine. I am not familiar with your machine. Is it clutch operated or HST?
The test would be to use a piece of scrap wood and see if it stops easily or keep turning. If it stops no problem. If it keeps turning check linkages and see if it is partially engaged.
   / PTO rotation
its clutch operated. I will try the piece of scrap wood thing. Thanks
   / PTO rotation
I just tried it and it stops when i put a small amount of pressure on it so it must be just the fluid flow. Thanks!
2021 John Deere S780 Combine (A50657)
2021 John Deere...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2014 John Deere 635F Grain Platform (A50657)
2014 John Deere...
2008 CATERPILLAR 320D L (A50854)
2008 CATERPILLAR...
