PTO push button yoke
/ PTO push button yoke #1
Kenfyoozed
Mobile, Al
1974 MF135
Is there a way to replace the push button on a pto yoke? or do i need to buy a whole new yoke or shaft? I was cutting my field with my 1974 MF135 and Bush hog 255 when I desended into a ditch and upon exiting it the pto shaft came off the tractor and about scared me to death. It looks like the push button part , that should lock it in place is now smooth. So now it wont stay in place. I asuume crossing the ditch to many times is what caused this.
So now how do I fix this? Do i have to have the oush button? or could I drill it out and use a bolt? I'd rather fix it right, but the field needs to be cut.
/ PTO push button yoke #3
There are "kits" available to replace those parts...IF...you know what brand the yoke is. MOST of those yokes have a cross drilled hole that will accept a pin to hold the yoke on the PTO stub shaft.
Forget BOTH ideas, replace the yoke. Less complicated and more reliable. Should be available at TSC among other places.
/ PTO push button yoke #4
In addition to what has been said, check your driveshaft lenght.. if it is too long, when you go into those ditches, it may be putting pressure on the yoke, and thus weaing the pin.. and not doing any favors tot he driveshaft or the pto bearing carrier.. in the past couple of years I've had to help fix 2 jd tractors that had the pto stub pushed in from employees using too long of driveshafts and not cutting them down before use.. etc.
soundguy
I will have to check on the length. Its not new, but there is not telling who did the pto length. It will shorten up a good bit. I would guess there is at least 6-8 inch space from the tractor pto shaft to the actual pto shaft when its compressed. If any thing i wonder if its to short, since it came off by it self. Im sure i had the top link to slack. It has always seemed to need a bit more length when sliding the yoke on, but maybe its me. I do a search to find out how to measure the pto shaft. Also how do i identify the yoke for replacement?
/ PTO push button yoke #6
If it was too short it simply would have pulled apart, and left that yoke onthe tractor stub banging around like a bull in a china shop.
Your push button yoke probably just simple wore out..
You know that you *might* be able to fix it.. or better/safer.. you know that you can simply replace it.
soundguy
/ PTO push button yoke #7
soundguy
Far more of these QD pins get ruined from the shaft bottoming out (too long) than ever just plain wear out. If your shaft is too long, be glad nothing else got trashed.
Thanks for the heads up on the shaft being to long. I checked it yesterday, and although i "thought" it had plenty of room , it actually only has about 1/2" space between the yoke and and tractor shaft when the yoke is fully compressed. Being a newbie, I didn't know how easy it was to remove the "push button". All I had to do was remove the spring and slide out the button. One area on the button was trashed. I was able to rotate the button after removing it, and re-inserting it, to where there was good metal for the lock to work. I will be replacing soon, but just needed to get field cut. I'll still double check the length.
/ PTO push button yoke #9
Be aware that when you lift the hog, the shaft may bottom out if you only have 1/2" of clearance.. if it bottoms out.. the pin will wear again, and you may be damaging your pto stub and bearing carrier.
soundguy
Thanks. I plan on measuring it all again this weekend and cut the shaft shorter if needed. The shaft should be 1" shorter than the shortest distance between the tractor and bush hog, right?
/ PTO push button yoke #11
That's a safe bet. Rememebr to cut equal lengths off each half shaft.. not all off one.
soundguy
/ PTO push button yoke #13
Hey intersting post, I just have picked up a used cutter ... worn quick releae pin ... can't see how to get it out ... but there is a hole that lines up and passes all the the way through the coupling and pto and baclk out ... whay kind of pin would work in that hole? I'll replace the yoke if I can't get the pin out but I need to use the hog right away .. :eek:(
NewBe Mike :eek:)
/ PTO push button yoke #14
NewBe Mike :eek:)
many farm stroes sell a pin with a half round bail. that is for going thru a pto shaft and coupling nad thent he bail clicks around and keeps the pin from falling out.
http://ep.yimg.com/ay/yhst-88039420719426/speeco-5-16-x-2-1-2-round-pto-locking-pin-p7956-6.jpg
2017 Ford Expedition SUV (A64557)
2017 Ford...
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2009 Ford F-450 Ambulance (A64556)
2009 Ford F-450...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
