PTO Pump Pressure Check
   / PTO Pump Pressure Check #1
Wayne_Freeman
Beaufort, SC
Kubota L3400
I purchased a used Kubota 4690 Backhoe/w PTO pump. The unit is working but seems to be weak. I don't have a manual but would like to put a gauge on the hydraulics and check the operating pressure. Can someone give me a heads up on how to do that?
   / PTO Pump Pressure Check #2
Find a gage. 3000 psi or more. Target value is between 1500 and 2500, depending on mfg spec.
Determine the size connection from a hose to an easy to get to cylinder. Probably JIC #8 at a guess. Get an adaptor to mate the gage to the hose. Move the control and hold to measure the pressure. The relief valve will only let it go so far. That's it in a nut shell. Surplus center will have everything you need.
jb
2018 RoGator 1100C (A53472)
2018 RoGator 1100C...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
CAT Skid Steer (A50322)
CAT Skid Steer...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
JOHN DEERE 8245R LOT IDENTIFIER 263 (A53084)
JOHN DEERE 8245R...
