PTO Pump driven with Jackshaft
/ PTO Pump driven with Jackshaft #21
That is quite a drop at them rpm's. Looks like chain it is! Good luck, let us know how it turns out.
/ PTO Pump driven with Jackshaft #22
I believe there is something else not right, as the pump should should be capable of developing 2000 psi while rotating, and working against a load . We know the pump is working because it will build up to 1100 psi. If the PTO pump is even turning at 270 rpm, is should be able to develop up to 2000 psi. Something is bypassing, or leaking, and if so, you will not be able to achieve the 2000 psi.
Can you substitute another valve to check flow and pressure?
/ PTO Pump driven with Jackshaft #23
You should have given us the complete story about all the things you have going on, so we can better help you.
I was a little curious about the engine, so I researched it.
Wisconsin Gasoline Engines - 4-Cylinder Air-Cooled Gasoline Engine - Model V465D
Seems like that engine will run at 3000 rpm, and produce 65 HP, However, the best torque is at 1800 rpm, and the HP at 1800 rpm is 47.5
Even at 1800 rpm, you have enough HP to run that pump, and we know the belts won't work. Maybe the chain can handle the HP/torque, maybe not.
Do you want to get all the GPM's out of the PTO pump? If so, whether you run the engine at 1800 rpm or 3000 engine rpm, you will need to figure out the ratio for the PTO match up.
If you are pumping fluid, where is the fluid actually going? You say that the relief valve doesn't come on, but you have the cyl at max extend. If the cyl is good and tight, the fluid will try and build up at the PRV for the valve.
Do you know if the solenoid valve is good?
Do you know if the PRV is good?
Looking at the pump data, you have to input 32 HP to the pump to get the 21 GPM's at 2000 psi
If you are only inputting 16 HP, 1000 PSI is all you will get.
/ PTO Pump driven with Jackshaft #24
It's like having a finsh mower and try to bush hog with it. If you got the hp it well smoke the belt. That is what is going on here.
/ PTO Pump driven with Jackshaft #25
Just for instance, if you wanted to run the 9.9 cu in pump at 200 rpm, you could pump 8.6 GPM's.
8.6 GPM's will take about 12 HP to develop 2000 psi, and that will only develop if there is a resistance to the force. If the fluid does not end up pushing on that cyl piston, then you will never see the pressure on your gage, or force generated by the cyl.
Being that I am getting confused and maybe others are too> Lets simplify this.
Lets say I run pump out to this valve (I have one)...
Notice it has P IN, P OUT, Tank, and not shown on this side but it has a Gauge port.
It is 500 PSI min 2000 Max.
Lets omit any cylinders, directional valves, subplates, manifolds, cartridge valves, filters, orifices, and any hoses except one from Pump to P and T on the relief to Tank. Lets say the hoses are 3/4".
We will plug the remaining P port with a pipe plug. Now we have NO question about anything except the Pump and this relief valve and 2 hoses......no return filter...just put the oil back in the tank...no restriction except the hose ID's, which are irrelevent for the example.
We lower the setting of the valve to 500 PSI and read that on the NEW gauge. Engine is running @ 1200 RPM as read on a Tach. All is well.
We turn the knob until we see 750 PSI....all is well.
We turn the knob until we see 1000 PSI...engine senses the load, but we see 1000PSI.
We turn the knob toward 1300 PSI, belts squeel, pump stops as seen by being able to read the words on the stopped belts.
Case closed.
Belts cannot deliver any more HP and will self-destruct if not shut-down or Relief lowered....and quickly !!!!
Engine is more than happy to destroy the belts and never misses a beat.
Enter the chain or a 3.00 ratio truck rear-end or a Motorcycle belt sprocket drive.
/ PTO Pump driven with Jackshaft #27
You must have some restriction to the flow to develop any pressure.
Valve shown is nothing but a relief valve. The volume of fluid will flow through this valve unless you have a cyl or motor to develop the pressure. If the cyl causes the pressure to build up to the relief setting, the relief valve will relieve the fluid to tank.
/ PTO Pump driven with Jackshaft #28
Basically he is saying his belt set up is only allowing him less then 20 HP.
I would think that the pipe-plug in the P port that would normally go on to a directional valve and motor or cylinder, would be 'some restriction' being that it IS a plug with no hole in it? It's as much restriction as you could get.....blocked.
I give-up.....will report how a chain-drive works when I get it converted to chain.
I feel like I'm on a merry-go-round.
Thanks for that chart, it agrees with my study of a different mfg's chart.
(4) 3v's can't do the job.
I have charts for chain, too now, and it looks like I'll be good to 30hp.
I can probably live with that.
The problem with 5v or 8v is achieving the right ratio with the shaft sizes I am dealing with. This is also a problem with chain.
Adding a full compliment (up to 10), of 3v's is not cheap either. That would only yeild 28.8-~30 HP.....similar to the #80 chain.
This engine has a 2" dia. output shaft. That limits the selection of the small pulley due to it needing a 2" bore. This 2" shaft requirement causes the sprocket/sheave, in the higher HP stuff, to become larger. The bigger the driver ....the bigger the driven needs to be to get the ratio. The smallest #80 I could locate is 13 teeth, and A 36 tooth or larger #80 or #100 or whatever, is not cheap although I did find one in #80 with 38 teeth and the 1-3/8" bore that will fit the 1-3/8" PTO shaft.
A 10 groove 3v in 10.6" is also hard to find cheap.
If it wasn't for the bulk of mounting and modifying one to be a single-axle unit-right-hand drive type-of-thing, I'd use a 9" Ford rear-diff in 3.00:1, as I know that ring/pinion exists and is common.
The only reason I keep trying to clarify what is going on in this thread, is for the next guy who may be contemplating such a drive system.
Hope this helps?
PS....another angle I have looked into:
a 4.5" cylinder @ 1600psi has more force than a 4" @ 2000psi
and a 5" @1400psi beats both of those by 1 ton.
Yes they would cycle slower.....about 1 second for the 4.5 and about 2 seconds for the 5"
Hmmmmm?
A smaller GPM PTO pump would help too on the HP requirements at the sacrifice of speed on the splitter cylinder only.
I want 2000psi for the hydraulic saw though.
Maybe I should add a 8gpm @2000psi pump just for the saw,feed-roller/hold-down,etc. and keep the 21gpm just for the splitter cylinder?
I have run the saw off of tractor hydraulics which is 6gpm@1500psi.
The saw can tolerate 8gpm@2000psi, which would be faster & more powerful.
Hmmmmmm?
/ PTO Pump driven with Jackshaft #32
Case closed.
Have you actually done this?
I am curious if the relief orifice will pass the volume of fluid produced by the pump. It will surely heat up quickly.
No I have not done this and don't intend to. I have the same thing with the aforementioned parts.
Have you tried to run a pump this large, driving it with belts?
/ PTO Pump driven with Jackshaft #34
Well, actually yes. I have a Case trencher with a similar Wisconsin engine, and it drives several pumps with a belt, although a special belt. It also drives the chain drive,for the trencher and turns a hyd pump for the BH.
Now you tell me. If I followed all of your other suggestions I'd have changed everthing except the drive method.... it's no wonder you have 8761 posts, beating around the bush like that.
The special belt must be a secret while taking me thru hydraulics 101?
/ PTO Pump driven with Jackshaft #36
Have you considered using a gear reducing box instead of the belts and chains?
Yes, see the post about using a 9" Ford rear-end with a 3.00 R&P.
Of course I'd have to dead-head one axle, eliminate both axle tubes, adapt the working axle to the 1-3/8" 6-spline shaft, and couple the pinion to the Wisconsin's 2" shaft....via a coupling or a u-joint affair.
Pretty bulky of a unit too, but it WOULD convey the HP.
There are probably other rear-ends that are physically smaller with ratios I could use, but most compact cars now-days are front-wheel drive.
I have seen post-hole augers made out of car rear-ends, so it could be done.
I do have a lathe and a mill and can weld....but?
Gear reductions rated at this kind of HP in 3:1 are not known to me.....like from Boston,etc.
Thanks for input though.
/ PTO Pump driven with Jackshaft #38
There should be no confusion here concerning hyd. As you can see, this is not your usual V belt. I know they make wide belts for certain equipment. I would not know where to get another one or the pulleys for it.
No tricks, just plain facts.
/ PTO Pump driven with Jackshaft #39
N8 are you building a fire wood processor????
glastron, Yes that is what I am working on building. It is not as large as yours though, but will have most of the same parts, only smaller scale.
I looked at yours and read what I could about your specs,etc. I especially like the way you use an air-cyl to displace chain oil as the saw moves up/down. I do not need that, as I am using a Fairmont saw, but I liked the thinking you did in coming-up with the idea.
If you would like to privately talk about it, feel free to PM me thru here.
I did post in a firewood processor thread a month or so ago about some of my ideas, but that thread seems to have died with my post.
Since then, alot of those ideas have changed or been mocked-up in some fashion.
I have collected a ton of parts, and am gradually building a section at a time.
This engine deal, is a separate wheeled buggy with the engine, gas tank, pump, hyd. tank, filters, and hoses with Qc's to connect to the splitting machine which will be a separate assembly.
I got side-tracked on the engine cart, due to needing to move cylinders,etc to watch the geometry of things and my tractors are 3 miles away, So I needed to begin working on this pump drive,etc. here at my shop to move things.....it needed done anyhow, as the tractors are too small for the speed I want.....one of them would have been fine for test movements though.
2021 Bobcat T62 Compact Track Loader Skid Steer (A64553)
2021 Bobcat T62...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
2020 HINO 268A  FLATBED (A67148)
2020 HINO 268A...
1999 Toro Groundsmaster 455-D 126in. Mower Commercial Riding Mower (A64194)
1999 Toro...
2007 Honda CR-V AWD SUV (A64557)
2007 Honda CR-V...
Case IH 5100 (A64119)
