PTO problem with B7500
/ PTO problem with B7500 #1
Joe44
Maryland
Kubota B7500
I have a Kubota B7500 with a front mounted snow blower. I shifted the PTO lever forward. It was hard to shift and there was a grinding noise. When I left the clutch out, the front PTO would not turn. Now the lever shifts back and fourth without depressing the clutch and the rear PTO turns a 540 rpm all the time.
/ PTO problem with B7500 #2
I would say check the linkages first.
/ PTO problem with B7500 #3
yes you have a linkage issue, make sure all pins and bolts are engaged in you pto lever linkage, something is not allowing it to be engaged or disengaged.
DevilDog
/ PTO problem with B7500 #4
Did you ever resolve your problem? I'm having a rear PTO problem on B7500. Mid PTO works fine, but rear PTO doesn't spin in either 540 or 960 position. I can't see any adjustment that would change rear working if mid PTO works.
2015 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
2011 GMC SIERRA 2500HD (A67714)
2011 GMC SIERRA...
2020 CATERPILLAR 316 FL EXCAVATOR (A65056)
2020 CATERPILLAR...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
1996 John Deere 7700 (A64911)
1996 John Deere...
SDLOOL Remote Controlled Mower (A64912)
SDLOOL Remote...
