PTO problem with B7500
   / PTO problem with B7500 #1
Joe44
Maryland
Kubota B7500
I have a Kubota B7500 with a front mounted snow blower. I shifted the PTO lever forward. It was hard to shift and there was a grinding noise. When I left the clutch out, the front PTO would not turn. Now the lever shifts back and fourth without depressing the clutch and the rear PTO turns a 540 rpm all the time.
   / PTO problem with B7500 #2
I would say check the linkages first.
   / PTO problem with B7500 #3
yes you have a linkage issue, make sure all pins and bolts are engaged in you pto lever linkage, something is not allowing it to be engaged or disengaged.
DevilDog
   / PTO problem with B7500 #4
Did you ever resolve your problem? I'm having a rear PTO problem on B7500. Mid PTO works fine, but rear PTO doesn't spin in either 540 or 960 position. I can't see any adjustment that would change rear working if mid PTO works.
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
