pto problem 2150
   / pto problem 2150 #1
smanna
upstate ny
cub cadet 2150
I have a 2150 with about 250 hrs on it. When I engage pto, engine stalls out. Starts and runs fine, new pto switch put in last fall, also new wire harness.
   / pto problem 2150 #2
Remove deck and check all spindles; make sure they all spin freely; also check idler pulleys. Make sure belt is routed correctly.
   / pto problem 2150 #3
Check your safety switch for the seat. I have a 2165 that did the same problem, would stall out or not come up to speed. After changing PTO's, PTO switch, I found out the switch under the seat to be bad. I cheated and put a jumper wire on instead of new switch. Maybe this will help for you.
   / pto problem 2150
I checked both suggestions, and the problem turned out to be with the safety switch. Up and running again, thanks for the help.
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2019 Ford F-550 4x4 Crew Cab Service Truck (A51692)
2019 Ford F-550...
2010 John Deere 200 Crumbler Seedbed Finisher (A53117)
2010 John Deere...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
UNKNOWN 16 T/A TRASH TRAILER (A53843)
UNKNOWN 16 T/A...
Worksaver grapple (A53473)
Worksaver grapple...
