PTO powerwashers
/ PTO powerwashers #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
A guy at work was telling me he was going to buy a powerwasher, curious if they make PTO powerwashers. If they dont it would make for an interesting project.
/ PTO powerwashers #2
That would be one heck of a power washer! Most of the power washers I've seen don't use anywhere near the Hp available from your average compact tractor.
/ PTO powerwashers #3
i love to use my tractor, but why would you want to fire it up just to use a power washer? for about $400 you can get a very nice gas power washer.
/ PTO powerwashers #4
</font><font color="blue" class="small">( i love to use my tractor, but why would you want to fire it up just to use a power washer? for about $400 you can get a very nice gas power washer. )</font>
It's a new "demolition model" pressure washer. Instead of just washing your deck with it, you can actually strip off the old decking entirely... saves time when you want to replace the decking. /forums/images/graemlins/grin.gif
/ PTO powerwashers #5
Can you say "water cannon"??!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ PTO powerwashers #6
</font><font color="blue" class="small">( It's a new "demolition model" pressure washer. Instead of just washing your deck with it, you can actually strip off the old decking entirely... saves time when you want to replace the decking.
)</font>
NOW i understand /forums/images/graemlins/grin.gif have no use for one but would sure like to see it work /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
/ PTO powerwashers #7
this is so you can clean the tractor up before you get home, so you don't have to explain what happened /forums/images/graemlins/smile.gif. Better tow a water trailer at the same time /forums/images/graemlins/smile.gif
/ PTO powerwashers #8
Isn't that the equivilent of the 1 1/2" Fire hose on a fire truck? They can make short work of an back porch. (Don't ask how I know please.) /forums/images/graemlins/wink.gif
/ PTO powerwashers #10
did you ever get one of these? That second option is impressive. 5000psi!!
/ PTO powerwashers #11
</font><font color="blue" class="small">( why would you want to fire it up just to use a power washer?)</font>
Because internal combustion engines do not like to sit for long periods. It takes work to maintain a fleet of tools, each with its own internal combustion engine. My goal is to have (not including the cars) just one engine to maintain: the tractor. Some things that can be run from the PTO rather than from their own engines are: generator, chipper/shredder, water pump, pressure washer, pneumatic pump with tank and tools, rototiller, lawn mower, rough cutter, siclebars, even electric chainsaws and line trimmers coupled to the generator. Since the tractor runs frequently, it's never hard to start. When some of these other things sit for a long time between uses, they can be a pain to get started. There's also the issue of stale fuel to drain, etc. I just find it cheaper, faster, and easier to hook these things up to the PTO and go.
/ PTO powerwashers #12
</font><font color="blue" class="small">( did you ever get one of these?)</font>
I'm waiting until the gas powered one which I now have wears out. When it does, I hope to get a PTO powered model.
/ PTO powerwashers #14
</font><font color="blue" class="small">( Did you get a price for them?)</font>
Sorry, no.
frank f15, PHD/auger, and concrete mixer are 2 more items that can be put on PTO rather than running on their own gas engines.
/ PTO powerwashers #15
I have only found 1 of these to be sold in the US, I think it was EasyKleen. I don't remember the exact quote, just that it was out of my price range. I think $1600 to $1700. I have the same plan, meaning I want a singe Engine to maintain, and have a low end Pressure washer that suits my current needs. As part of beginning this project I have already acquired a New Pressure Washer Pump manufactured by Giant. It puts out 3500 PSI at 4GPM, the important issue from my perspective it that the shaft rotation speed to achieve that PSI/GPM is 1340RPM. I also have a new Right angle Gear Box with a 1 to 2.5 ratio (540 X 2.5 = 1350). It was to be used on a mower deck, but I have concern that it is not built to be driven Via a PTO and when I put a 17HP pto shaft to it the gears may not hold up to the strain. By the way the Pump shaft can be rotated to either side of the pump, so I think I can easily match it to the rotation of what ever PTO attachment I end up using. I do have a few LoveJoy couplers to mate the pump to the gearbox in a flexible sort of way. No experience with welding here so for the moment this project is tabled till at least winter, But I would like to hear what others are thinking.
Forklift Boom (A62679)
2012 CARGO CRAFT 24' T/A ENCLOSED TRAILER (A65643)
2012 CARGO CRAFT...
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
445 (A63290)
445 (A63290)
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
Tumblebug Hay Hauler (A64126)
Tumblebug Hay...
