3-Point Hitch PTO operation from ground with 4010 Compact JD.
   / PTO operation from ground with 4010 Compact JD. #11
Same thing on my 2210. I think it says in the manual that it can be run out of seat but I can't figure it out. Don't have any attachments that require it so I don't sweat it.
Yes, like Ralph the 4010 was never setup to allow off-seat operation, unless you do some modifications. A hidden bypass switch wired in parallel is easy to install, and keeps the regular switch active for general use.
Thanks but"easy to install" on this tractor is a relative term, especially for me.Hate to have the switch fail when I'm running the generator, at night in the freezing cold. Probably will stick with the manual hold down suggestions.
   / PTO operation from ground with 4010 Compact JD. #13
OK, but anything can fail "at night, in the freezing cold"
How true. I think I found where I can "splice in". It will be a better option. Right now we have 40" of snow on the ground and expecting 3" of rain tonight, temp in the 40's. I need a break
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56435)
2023 Kubota...
Hose Reel (A55758)
Hose Reel (A55758)
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
