PTO operated machine
/ PTO operated machine #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
I saw one of these years ago. Did not know what it was. Now I do. Do you know what it is? No cheating
/ PTO operated machine #2
Never got to use one but my great uncle had one. Think it was used to dig potatoes with a tractor.
/ PTO operated machine #5
Potato digger. Although in this area you're more likely to see them used for digging ginseng roots.
-rus-
/ PTO operated machine #6
Used to take yellow lines off highway :confused::cool::confused2::ashamed:;):thumbsup:
If you right click on the image, click image info, there is the answer.
/ PTO operated machine #9
Great Pic JJ. Thanks for sharing
/ PTO operated machine #10
Where was that when I was a kid?
/ PTO operated machine #11
We had one years ago, but not PTO driven. An old IH with spade wheels, and chain driven. Actually horse drawn, Dad took the trucks out from under the front, and attached to the drawbar.
We never planted less than 100 lbs. of potato's, and one year 500 lbs. That baby sure saved a LOT of work..!! Wish I had it now..!
/ PTO operated machine #12
Same here. We used to have one we owned jointly with another family who had the tractor to pull it. That was a beautiful machine and sure saved on digging forks. Our's was not pto driven, it was ground drive with steel wheels and very aggressive tread. We would harvest around a ton of potatoes out of our garden and then another good amount from our friend's garden. One problem it had was, rocks the size or a little smaller of num. 2 stone would get jammed in the conveyor an stop the machine. It would just make the wheels skid but was a pain to get out.
When we moved, the digger stayed with the tractor that could pull it. I heard recently they still use it. Looking again to find something to dig potatoes other than a digging fork.
Tucker,
Have you seen one of these potato plow. Looks easy enough to build.
/ PTO operated machine #14
Tucker,
And unless in sand, it looks frail enough to not last long :) The vertical member looks a bit weak as does the horizontal. But in sand, should roll out a few potatoes.
/ PTO operated machine #15
I have seen them in action and they do work pretty well. That is all we used before we got the fancy machine. An old horse drawn potato plow chained the the back bumper of the van. :D Boy, was that fun. :thumbsup:
I think that plow does look a little lacking in strength for hard soil but some steel and a welder would fix that.
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
Tufline PT 12' Box Blade (A64119)
Tufline PT 12' Box...
Lot 602 (A62613)
Lot 602 (A62613)
New Landhonor 72" Rock Bucket (A62679)
New Landhonor 72"...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
