PTO operated machine
/ PTO operated machine #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
I saw one of these years ago. Did not know what it was. Now I do. Do you know what it is? No cheating
/ PTO operated machine #2
Never got to use one but my great uncle had one. Think it was used to dig potatoes with a tractor.
/ PTO operated machine #5
Potato digger. Although in this area you're more likely to see them used for digging ginseng roots.
-rus-
/ PTO operated machine #6
Used to take yellow lines off highway :confused::cool::confused2::ashamed:;):thumbsup:
If you right click on the image, click image info, there is the answer.
/ PTO operated machine #9
Great Pic JJ. Thanks for sharing
/ PTO operated machine #10
Where was that when I was a kid?
/ PTO operated machine #11
We had one years ago, but not PTO driven. An old IH with spade wheels, and chain driven. Actually horse drawn, Dad took the trucks out from under the front, and attached to the drawbar.
We never planted less than 100 lbs. of potato's, and one year 500 lbs. That baby sure saved a LOT of work..!! Wish I had it now..!
/ PTO operated machine #12
Same here. We used to have one we owned jointly with another family who had the tractor to pull it. That was a beautiful machine and sure saved on digging forks. Our's was not pto driven, it was ground drive with steel wheels and very aggressive tread. We would harvest around a ton of potatoes out of our garden and then another good amount from our friend's garden. One problem it had was, rocks the size or a little smaller of num. 2 stone would get jammed in the conveyor an stop the machine. It would just make the wheels skid but was a pain to get out.
When we moved, the digger stayed with the tractor that could pull it. I heard recently they still use it. Looking again to find something to dig potatoes other than a digging fork.
Tucker,
Have you seen one of these potato plow. Looks easy enough to build.
/ PTO operated machine #14
Tucker,
And unless in sand, it looks frail enough to not last long :) The vertical member looks a bit weak as does the horizontal. But in sand, should roll out a few potatoes.
/ PTO operated machine #15
I have seen them in action and they do work pretty well. That is all we used before we got the fancy machine. An old horse drawn potato plow chained the the back bumper of the van. :D Boy, was that fun. :thumbsup:
I think that plow does look a little lacking in strength for hard soil but some steel and a welder would fix that.
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2015 Ford F-150 Ext. Cab Pickup Truck (A61568)
2015 Ford F-150...
2012 International Prostar (A63118)
2012 International...
2018 CATERPILLAR 305.5E2 CR EXCAVATOR (A62129)
2018 CATERPILLAR...
2008 Genie S-60 (A61166)
2008 Genie S-60...
2013 Komatsu WA320PZ Articulated Wheel Loader (A60352)
2013 Komatsu...
