PTO Not fully disengaging! Jinma 224
   / PTO Not fully disengaging! Jinma 224 #1
dh0765
I am having a problem with the PTO not fully disengaging. When I move the PTO lever to Neutral, the PTO shaft continues to turn, but not a full speed. I can stop it by putting something against it, but when I let go, it starts to turn again. Any help is appreciated.
   / PTO Not fully disengaging! Jinma 224 #2
That's normal.
It's the oil inside being flung around.
Thanks for the fast reply. So this is normal and will not harm anything?
   / PTO Not fully disengaging! Jinma 224 #4
Perfectly normal. Don't worry about it at all.
//greg//
Greg_G and Willl, thanks so much for your replies!
   / PTO Not fully disengaging! Jinma 224 #6
That makes me a little concerned....I disengage the PTO before I attatch my finish mower....am I not safe in doing that? Should the engine be OFF when I attatch the implement? Is there any way that the PTO can start turning by itself? I would not want to have my hand right on it and have the thing start running, that could hurt....or worse...
   / PTO Not fully disengaging! Jinma 224 #7
With your PTO disengaged, there is no problem.
It still may spin because of the drag or parasitic friction causing it to turn, but it is not mechanically engaged. It will stop turning as soon as you get the PTO shaft to it. I can stop mine by hand. You can try to stop yours (if it turns with the PTO disengaged) by using a 2 x 4 first. As long as the PTO is disengaged, it should be good to go.
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
