PTO mounting problems
/ PTO mounting problems #1
MtHam
Northern California coastal hills
Kabota B3030
Every time I mount a PTO device on my B3030, getting the pto shaft to slip onto the male protrusion of the tractor is a PIA. I always try to align the device (chipper/shredder, logging winch, tiller etc) so that the shaft is horizontal and in line. Any suggestions?
/ PTO mounting problems #4
Are the splines on both sides properly aligned?
/ PTO mounting problems #5
I had the same problem with the PTO when my tractor was new. After I used it for a while it got easier to slip the shaft on.
/ PTO mounting problems #6
Clean and lubricated may not be enough. Sometimes you have to remove the protective layer of paint on the pto shaft. A good stiff wire brush on both the pto shaft and the inside of the implement coupler may help. THEN lubricate.
Ken
/ PTO mounting problems #7
I second Ken's response. I've had trouble with paint inside the female end of the coupler on every new implement I've bought. Use a small file to clean it out of each spline and it'll drop right on.
/ PTO mounting problems #8
The shaft on the bush hog is hard for me to connect, doing the following helped.
I use a rope to tie the shaft up to hold it about level with the tractor connection so I don't have to hold the weight steady for an extended period.
It has a spring loaded push button that takes a lot of force to hold down in order to clear the grooves. I can't do that for long without it hurting, and needing to take a break. So use a screwdriver style handled socket to push it in.
Then it is a relaxed operation to fiddle with the positioning without having to keep taking a rest and starting over again.
/ PTO mounting problems #9
Maybe I’m the only one dumb enough to do this, but I used to always press the button down and then try to spin the shaft on the implement to get it lined up with the tractor PTO shaft. It dawned on me one day that it’s MUCH easier to spin the tractor PTO shaft until the implement shaft slides in place. These days it seldom takes more than a few seconds to get hooked up.
/ PTO mounting problems #10
Maybe I知 the only one dumb enough to do this, but I used to always press the button down and then try to spin the shaft on the implement to get it lined up with the tractor PTO shaft. It dawned on me one day that it痴 MUCH easier to spin the tractor PTO shaft until the implement shaft slides in place. These days it seldom takes more than a few seconds to get hooked up.
On some tractors the PTO won't turn. And trying to turn the shaft on a big cutter isn't easy either. But in any case, often the problem isn't with getting the splines aligned. Too often the fit is just too tight, especially on newer equipment.
Ken
/ PTO mounting problems #11
The spring is strong and if new, not broken in. I suggest you also spray the spring mechanism with some liquid lubricant like PB Blaster or WD40.
/ PTO mounting problems #12
I think the different couplers on the implement PTO have a lot to do with it. The ones that have a collar on them are a lot harder to put on than the ones that just have a button to push. Trying to pull back on a collar and push the coupler on at the same time is more difficult than pushing a button.
/ PTO mounting problems #13
"Trying to pull back on a collar and push the coupler on at the same time is more difficult than pushing a button."
Aye!
/ PTO mounting problems #14
I too have trouble at times. Lining up the slines is a real PIA. I wonder if match marking them with a dab of paint would help. I'm not sure what is meant by spinning the PTO shaft. I am pretty sure my shaft don't spin. ( no pun intended) Usually once the slines are aligned mine usually goes right on. Although, I agree, I prefer buttons over collars. I do like the rope idea. Some of those driveshafts sure get heavy.
I can always tell if I am going to have a bad day by how long it takes to get the pto shaft connected. Some days they go right on and other days I have to talk to Jesus a couple times to make it happen.
CJ
/ PTO mounting problems #15
How about you sit in the seat and swear while the little woman hooks it up.
/ PTO mounting problems #16
This tractor has an independent PTO, so with the motor off and the PTO in the neutral position, the PTO output shaft on the tractor turns easily by hand. Once the splines are aligned, it should be very easy to connect.
/ PTO mounting problems #17
If you have the new collar type PTO coupler make sure that you are properly puckered before you begin the task. If you have the old style push button type coupler life is good.
/ PTO mounting problems #18
Independent is done in different ways. Some, like your tractor and mine are out of gear when disengaged. Others are only declutched to stop the drive. Those usually have a brake to keep clutch drag from driving the stub. They are harder to work with and also present a much higher likelihood of spontaneous engagement than the former.
...larry
/ PTO mounting problems #19
You are correct -good point. But since this thread is specifically about a B3030, I limited my response to just that tractor.
213064 (A64276)
213064 (A64276)
2014 FREIGHTLINER COLUMBIA GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2014 FREIGHTLINER...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
2009 Volkswagon Jetta Sedan (A61574)
2009 Volkswagon...
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
