PTO locked up
   / PTO locked up #1
nedbrod
Oriental, NC
honda 6522
B23 Kubota tractor with the pto stuck. It's between the rear pto and the front underbelly pto and I can't move it. I'm afraid to really push it hard as it may snap the handle. Hopefully someone has either experienced this before or has an idea how to get it moving. Thanks in advance.
   / PTO locked up #2
If the lever is attached to a shaft that goes into the transaxle case, start spraying it with penetrating lube. Tap the side with a small hammer to get the lube to seep in. Many times the seal in inboard so water can rust the shaft so it can't move.
   / PTO locked up
Ruffdog, you nailed it. Took a little time but now works perfectly. Thanks.
(4) 24' Stand Alone Texas Panels (A50515)
(4) 24' Stand...
2016 Ford Explorer...
2021 Kubota KX033-4 Mini Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 Kubota...
2006 Capacity TJ7000 (A50120)
2006 Capacity...
Bad Boy Maverick 5200 Zero Turn Mower (A50514)
Bad Boy Maverick...
UNUSED JCT QUICK ATTACH 84" GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
