PTO locked up
/ PTO locked up #1
nedbrod
Oriental, NC
honda 6522
B23 Kubota tractor with the pto stuck. It's between the rear pto and the front underbelly pto and I can't move it. I'm afraid to really push it hard as it may snap the handle. Hopefully someone has either experienced this before or has an idea how to get it moving. Thanks in advance.
/ PTO locked up #2
If the lever is attached to a shaft that goes into the transaxle case, start spraying it with penetrating lube. Tap the side with a small hammer to get the lube to seep in. Many times the seal in inboard so water can rust the shaft so it can't move.
/ PTO locked up
Ruffdog, you nailed it. Took a little time but now works perfectly. Thanks.
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2014 FREIGHTLINER SPRINTER 2500 4X2 CARGO VAN (A59906)
2014 FREIGHTLINER...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
2020 INTERNATIONAL LT625 TRUCK TRACTOR SLEEPER (A59906)
2020 INTERNATIONAL...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
