PTO locked up
/ PTO locked up #1
nedbrod
Oriental, NC
honda 6522
B23 Kubota tractor with the pto stuck. It's between the rear pto and the front underbelly pto and I can't move it. I'm afraid to really push it hard as it may snap the handle. Hopefully someone has either experienced this before or has an idea how to get it moving. Thanks in advance.
/ PTO locked up #2
If the lever is attached to a shaft that goes into the transaxle case, start spraying it with penetrating lube. Tap the side with a small hammer to get the lube to seep in. Many times the seal in inboard so water can rust the shaft so it can't move.
/ PTO locked up
Ruffdog, you nailed it. Took a little time but now works perfectly. Thanks.
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
3PT HYD SCRAPE BLADE (A63291)
3PT HYD SCRAPE...
Engine (A59228)
Engine (A59228)
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
John Deere 2155 (A62177)
John Deere 2155...
John Deere XUV825E (A61307)
John Deere XUV825E...
