3-Point Hitch PTO jumps out of gear & Leveling Crank stuck
   / PTO jumps out of gear & Leveling Crank stuck #1
SteveG1
Emmitsburg, MD
1970 Massey Ferguson 135
I have a 1970 MF-135 and cannot figure out why the PTO jumps out of gear while mowing. I have to work while hanging on to the PTO lever to prevent it from jumping out of gear. It does not happen all the time but will do it more frequently when under a heavy load or going over bumps.
Also, something I never needed to use until I got my new bush hog is the leveling crank. It is greased but is stuck. I can't get it to turn.
Any ideas on both these problems? Thanks for the help.
   / PTO jumps out of gear & Leveling Crank stuck #2
You have two stage and not ipto?
   / PTO jumps out of gear & Leveling Crank stuck #3
Levelingcrank....bent or screwed in to the end and then stuck ?
I don't have a lot of experience with tractors. This is my first one. I bought it used about 8 years ago and have been learning ever since. All I know is I have two PTO options; proportional ground speed and proportional engine speed. I only use engine speed.
I never used the leveling crank before. I knew it was there but never needed to use it. My finish mower and blade were always level. However, my new bush hog is not level. That said it looks like it is in. The handle will not move in either direction.
   / PTO jumps out of gear & Leveling Crank stuck #6
Remove the cover with the PTO handle, look if there are heavy wear on the gear that engages the PTO. Any slack in the bearing at the rear?
No slack in the bearing. Everything seems tight. I didn't see excessive wear.
   / PTO jumps out of gear & Leveling Crank stuck #8
I think there is a spring loaded lock on the lever, did that work?
   / PTO jumps out of gear & Leveling Crank stuck #9
I unstuck my leveling crank by heating the heck out of it then forcing more grease into the zerk. Yes, I think there was fire, but it was years ago and I was outside.
   / PTO jumps out of gear & Leveling Crank stuck #10
the rod that comes out of the crank assembly should be able to be turned with a stillson wrench just make sure the handle is not locked when you start braking it loose
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
