PTO issues DS 4110
/ PTO issues DS 4110 #1
Kioti Lee
Kalama wa
Kioti DS 4110
Turned pto switch on and nothing happened. Assumed :cool2: it was the switch and ordered a new one, but as I think about it and look at switch I am not so sure. The tractor won't start with switch on so current must be going thru switch. Right? . What else could be causing the problem and how should I test it?
/ PTO issues DS 4110 #2
Check the PTO relay. It's likely the relay or the actual solenoid if the start interlock works.
Where should I look for relay and or solenoid ?
/ PTO issues DS 4110 #4
Check the other safety switches too, I forget which ones pertain to PTO operation, but there are a bunch.
/ PTO issues DS 4110 #5
there's also a PTO fuse you should check also. I've got an intermittent short that I have yet to completely figure out. I know in general where it is but I've gone through a handful of fuses trying.
Thanks for the input. Bad relay..waiting for part now
NEW HOLLAND 254 - 10' HAY TEDDER (A64277)
NEW HOLLAND 254 -...
Dirt Dog 3PBU Hay Unroller (A65579)
Dirt Dog 3PBU Hay...
2022 EZ-GO ELITE...
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
Skid Steer Bale Spear (A65640)
Skid Steer Bale...
