PTO issues DS 4110
/ PTO issues DS 4110 #1
Kioti Lee
Kalama wa
Kioti DS 4110
Turned pto switch on and nothing happened. Assumed :cool2: it was the switch and ordered a new one, but as I think about it and look at switch I am not so sure. The tractor won't start with switch on so current must be going thru switch. Right? . What else could be causing the problem and how should I test it?
/ PTO issues DS 4110 #2
Check the PTO relay. It's likely the relay or the actual solenoid if the start interlock works.
Where should I look for relay and or solenoid ?
/ PTO issues DS 4110 #4
Check the other safety switches too, I forget which ones pertain to PTO operation, but there are a bunch.
/ PTO issues DS 4110 #5
there's also a PTO fuse you should check also. I've got an intermittent short that I have yet to completely figure out. I know in general where it is but I've gone through a handful of fuses trying.
Thanks for the input. Bad relay..waiting for part now
2022 EZ-GO ELITE...
2018 Chevrolet Impala Sedan (A64557)
2018 Chevrolet...
2018 MACK PINNACLE (A65643)
2018 MACK PINNACLE...
58in Wagon Wheel Bench (A65583)
58in Wagon Wheel...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
