PTO issues DS 4110
   / PTO issues DS 4110 #1
Kioti Lee
Bronze Member
Kalama wa
Kioti DS 4110
Turned pto switch on and nothing happened. Assumed :cool2: it was the switch and ordered a new one, but as I think about it and look at switch I am not so sure. The tractor won't start with switch on so current must be going thru switch. Right? . What else could be causing the problem and how should I test it?
   / PTO issues DS 4110 #2
Check the PTO relay. It's likely the relay or the actual solenoid if the start interlock works.
Where should I look for relay and or solenoid ?
   / PTO issues DS 4110 #4
Check the other safety switches too, I forget which ones pertain to PTO operation, but there are a bunch.
   / PTO issues DS 4110 #5
there's also a PTO fuse you should check also. I've got an intermittent short that I have yet to completely figure out. I know in general where it is but I've gone through a handful of fuses trying.
Thanks for the input. Bad relay..waiting for part now
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
1267 (A50490)
1267 (A50490)
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2015 Kubota L2501D (A50120)
2015 Kubota L2501D...
2008 GMC C7500 Altec LRV55 55ft Forestry Chipper Bucket Truck (A50323)
2008 GMC C7500...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
