Pto install
/ Pto install #1
jamesdecanter
turrell ar
801 powermaster
I have rebuilt my pto shaft on my 801 powermaster. When installing it catches on the shifter and pulls it forward but will go no further. Should I remove the part it slides into?
/ Pto install #2
Without more of a description or pictures it's a little hard to visualize what you are trying to do. Pictures would help the most.
/ Pto install
It would be difficult to get pictures. The pto shaft inserts all the way to the final collar. I took the side plate off to make sure. The problem is when I attempt to make it go the final 6 inches, it carries the pto shifter with it and jams the shifter. I am wondering what I would encounter if I remove that final destination part. It is a big collar with the pto shift built into it. The shifter on the side slides something to engage. I thank you for your help
/ Pto install
Yes it is. I have looked for hours trying to find that image. If you could please tell me the next steps. Thank you. I am in uncharted territory, at least for me.
/ Pto install #9
part 10 is attached to the cover and lever
/ Pto install
Yes. It still catches on the shifter mechanism, pushes it forward. If I force it past this position, which is about an inch, it will go all the way in but then the shifter will not move.
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2008 IC Corporation PB105 School Bus (A60352)
2008 IC...
7021 (A55851)
7021 (A55851)
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
