PTO Hydraulic
   / PTO Hydraulic #1
LarryP
I have a Satoh 630D and my PTO arms is slowly lowering , usally takings several minutes or longer to lower. Is there a filter that I need to clean on the hydraulic system or is there something else wrong with it?
HELP!!!!!
   / PTO Hydraulic #2
Not sure what "PTO arms" you are referring to, but assume you are talking about the 3-point lift arms supported by the rock shaft. There is likely a valve (knob or lever control) that can be opened to allow the lift arms to drop faster. Check the manual, or look around under the seat for such a knob. PS: PTO stands for Power Take Off and is the drive shaft for powering equipment such as a rotary cutter. I hope this helps.
   / PTO Hydraulic #3
I am not familiar with your model, but on my MT180D there is a knob under the seat that effects the speed the 3PH raises and lowers. There is also a filter for my transmission/hydraulic fluid. It really helped the speed of my FEL when I cleaned the filter. I did not notice a change in the 3PH, but it is worth a try since you need to clean that filter regularly anyway.
I hope that is helpful.
Robert
2025 INDUSTRIAS AMERICA 227T 7' X 22' HYD TILT TRL (A51247)
2025 INDUSTRIAS...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
UNUSED FUTURE HYD 16" AUGER (A51248)
UNUSED FUTURE HYD...
