PTO Generators: Winco
   / PTO Generators: Winco #61
</font><font color="blue" class="small">( The water heater takes 5500 watts. BUT, that is with two elements. Even with HEAVY water usage I have never seen both elements on. Sooo, I'm guessing that really it only needs 2750 watts if we don't use too much water or let it cool down. )</font>
My parents were without power for about 3 weeks in 04 after the multi-hurrican fiesta in florida. What I did was have them hook up their genny to the water pump, and pump up water pressure.. then hook over to the water heater, and let it run for 30 minutes.. kick the water heater off, and leave the pump hooke dup for pressure. That yields enough shower water to take a decent warm shower with constant pressure. Had it set so they could then power a window ac unit so they could sleep. Once my aunt got power back, she lent them another 5500w genny, and I hooked up on to the pump and the other to the water heater and ac..( fridge and a single lamp) that way my stepfather didn't have to constantly plug and unplug stuff.
I had my 12kw pto genny.. that convinced him to get one.. course he outdid me.. got a 24kw /forums/images/graemlins/shocked.gif Makes mine look a tad wimpy in comparison!!! Guess he got tired of my mom complaining about to power!!! /forums/images/graemlins/grin.gif
Soundguy
   / PTO Generators: Winco #62
</font><font color="blue" class="small">( The side effect of this is that some homeowners take some risks with a live power source that they probably shouldn't take )</font>
Looks like good justification for a utility disconnect switch after the can, and before the breaker.
Soundguy
   / PTO Generators: Winco #63
Inspector507,
I looked at my plate on the waterheater again. You are right. There are two elements both at 5500 watts. But I guess only one works at a time since the plate also said max wattage is 5500 watts.
I need to put out the manual cuz what is in my head is that the top elements only goes on if a lot of water has to heat up. The water heater has two LEDs, one for each element. I have never seen the the top one lit. I was looking at it last night since everyone had just taken showers and baths. Its an 80 gallon unit and with our low flow heads on the shower it would take along time to run out of hot water.
Still don't know what to do about a generator..... /forums/images/graemlins/grin.gif
Later,
Dan
   / PTO Generators: Winco #64
I think the way most 2 element electric water heaters work is:
Cold water is fed to bottom of tank
Hot water is taken from top of tank
When top thermostat calls for heat, it cuts off current to lower element & turns on top element. When top thermostat is satisfied, it transfer current to lower thermostat & it will heat till satisfied.
Since cold water is fed to bottom, it will most likely turn on first, then when top gets cold enough to turn on thermostat, the top thermostat will cut current off to the bottom & turn top element back on.
   / PTO Generators: Winco #65
If anyone is getting the generator, remember to do the transfer switch correctly. You can have a " vital" subpanel ( 60 Amp/240?)with the two manual interlocking feed breakers for pretty cheap. But only the loads wired to that panel will run off the generator. There are the retrofit panels that split each of the desired circuits( utility power or backup generator). Then there are the total swapover switches. A manual one just past the meter or an automatic with auto start genset$$$$. These are in ascending order of price. Of course the cheapest is a bunch of extension cords and wire/ wire nuts to splice into the loads right from the generator panel. From an industry insider please don't do it on the sly. I work in a nuke power plant, and despite the media spin to the contrary the most dangerous aspect of the plant is our product- Electricity. Linemen get paid very well, look at what happens when they mess up, or you backfeed them ( Do a search, please have an empty stomach ). Those guys deserve the pay, dont kill them with a single error.
   / PTO Generators: Winco #66
Our electrical subs always use something called a GenTran panel. THey wire up the "vital" circuits (as dieselmh mentioned) to that panel: water, some lighting, freezer or fridge, boiler, etc. When line power dies, the GenTran either manually (or, more $$, automatically) disconnects the line power switches itself to your genny. You either then manually (or, more$$, automatically) start your genny and it runs those circuits. If there's no neighbors in sight (without generators) a neon bulb on the main panel is a good clue for when the main power returns. The GenTran keeps the linemen safe and the only limit is you have to buy a big enough one to run the circuits you want. They are a few hundred $$ plus installation. Jim
   / PTO Generators: Winco #67
</font><font color="blue" class="small">( From an industry insider please don't do it on the sly. ..... dont kill them with a single error. )</font>
What i can't figure out is the problem with people throwing their main breaker, if they backfeed their house thru a 220v plug ( welder recep.. dryer.. etc.. ).. seems like a 1 second fix that would stop problems...
Soundguy
   / PTO Generators: Winco #68
Backfeed onto the utility system, it happens because most people have no idea how electricity works. Those asking questions here that don't know at least know they don't know and are trying to upgrade their knowledge. Some of the questions asked on various forums re electrical wiring are terrifying. But at least these people are asking. Think of all those who blindly blunder through life not knowing squat and not seeking to change that condition.
   / PTO Generators: Winco #69
</font><font color="blue" class="small">( Think of all those who blindly blunder through life not knowing squat and not seeking to change that condition. )</font>
Hence the saying "Ignorance is bliss."
I agree with Soundguy, if I were fortunate enough to even have a generator, all I would do is wire it up to back-feed through the panel and turn off the MCB. Then you just turn off non-essential breakers, watch carefully what you turn on and enjoy.
But I think you're right, people by-in-large are idiots. And what's worse is they will usually believe anyone who sounds like they know what they are talking about (even if that person is a bigger idiot, I'm thinking of the big-box home improvement employees here). That's what really scares me.
   / PTO Generators: Winco #70
Been there, done it that way, (by flipping off the main breaker). However, what about the neutral? It doesn't go thru the breaker, and is how power is sometimes backfed to the grid. Not supposed to... but sometimes does.
Another thought...
To tell if your grid power is back on, how about a LED on each leg of the incoming power, instead of flouresent. Much less power draw. (assuming LED's can be found for AC power, since all I have are used with DC.
Or a simple voltmeter wired up to run all the time, set neatly in a subpanel.
David from jax
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
40' CONTAINER (A57192)
2025 Spirit Carriage Cart (A55853)
2025 Spirit...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
