PTO Generators, been here before?
/ PTO Generators, been here before? #21
Soo can I run a big generator with a light load powered by a BX?
My BX1500 is the best tractor I have to operate my 12KW gen. ... Course I can only get 7-8KW, but the power is dead stable with load fluctuation up to that limit. Wish it had a bigger fuel tank. ;) -- If I need full gen capacity I run it on the L2550.
/ PTO Generators, been here before? #22
I used a PTO set for years. Worked well, but I am glad those days are over.
Unless I am wrong, no tractor has a shut down system for temp or oil failure. Something to think about before leaving a tractor running wide open unattended.
Why is the tractor wide open?
/ PTO Generators, been here before? #23
Sure can, just fine. I used a 12Kw gen on a 650 JD that had maybe 14hp at the PTO for years before getting a 3520.
/ PTO Generators, been here before? #24
First, define "big generator". Then, define "light load".
See my BX + PTO generator setup and power outage experience here:
Sandy -- 12 days without power: what worked, what didn't ... - AR15.COM
wrooster
/ PTO Generators, been here before? #25
wrooster that was an interesting read. Having the dual generator setup was a definite plus when it came to fuel consumption.
Thanks for the link.
/ PTO Generators, been here before? #28
If operated at part throttle the lower than 60Hz from the generator will wreck some electrical and electronic equipment.
You know, there IS something between wide open and part throttle... At least there is on all of MY tractors...
It's called "pto speed"...
SR
/ PTO Generators, been here before? #29
SR
Does anyone have an inexpensive easy to use tool to measure PTO speed?
I'm thinking like a little IR gun you point at a marker you put on the shaft and it tells you rpm.
/ PTO Generators, been here before? #30
SR
/ PTO Generators, been here before? #31
I have digital readout on the tractor that tells me the pto speed.
/ PTO Generators, been here before? #32
Your tach has the pto speed marked on it, and the pto gen set has a meter, for fine tuning that speed, to get the proper voltage...
SR
/ PTO Generators, been here before? #33
/ PTO Generators, been here before? #34
PTO speed is not what you are looking for. You want the PTO to spin the generator at the rpm needed to produce 60 Hz. PTO speed is really irrelevant to the speed actually needed for clean generator power.
Invest in a meter to tell when you are producing 60Hz electrical power and set your throttle to that speed.
/ PTO Generators, been here before? #35
Generator manufacturers understand that, so they make the gearboxes to that 540 RPM input = proper speed for 60hz output.
/ PTO Generators, been here before? #36
Yes, that is the intent. As long as you are comfortable "house camping" with limited power for the majority of the time, it's a good setup. As I wrote, my overall fuel consumption was a mere fraction of the folks using 5 to 7.5KW generators. The unavailability of gas for a week or so made using such fuel-hogging gas units really cumbersome, so having a tiny inverter generator was really handy. Using the PTO generator for just a half hour or so per day made it possible to use all the "big stuff" (deep well pump, and ultimately the washer and dryer) with minimum fuel consumption.
wrooster
/ PTO Generators, been here before? #37
As noted by several folks above, in practice you don't really care what the exact PTO speed is. You simply "tune" the tractor throttle setpoint until the output frequency is nominally 60Hz (it may vary from about 58 to 62Hz depending on load). Most all PTO generators incorporate either a digital frequency gauge or a simple set of "idiot lights" that help determine whether you are too low or high in engine RPM.
Every PTO generator will consist of the alternator head itself mated to an up-conversion gearset. The nominal 540RPM input to the gearset will result in either 1800RPM output (for use with a 4 pole alternator head) or 3600RPM output (for use with a 2 pole alternator heard). There are advantages and disadvantages with both alternator head types, but in general a 3600RPM/2 pole head will have somewhat greater transient (surge) capability due to the faster rotating mass.
In the second picture below, note the black cast iron assembly between the PTO coupler guard (on left) and the alternator head (on right). That assembly houses the up-conversion gearset, bathed in oil. There is a fill plug on top for 90wt gear oil.
wrooster
/ PTO Generators, been here before? #38
A Kill A Watt is only $20-30 or so & among other things it will measure Hz. Its not easy to see at distance & not rated for outdoor use. The P4400 is the origonal one & does Hz at least, not sure for other variants.
If there were a better weatherproof meter at a reasonable price I might consider it for my generator as it is an older unit with just a voltage range indicator not any frequency type gauge. My Kill A Watt will get the job done for now. Anybody know of any? I Googled a bit a while back, but couldnt find anything.
/ PTO Generators, been here before? #40
Thanks Aaron.
And I know about the built in measuring devices but I don't trust them without verification. Especially if they are digital.
Well, measuring the RPM won't help you any, you need to measure the electrical output of the generator NOT what the RPM of the tractor PTO is...
SR
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
MI-T-M HDS-3005-Z004 PORTABLE PRESSURE WASHER (A65054)
MI-T-M...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
