PTO Generators - Any Favorites?
   / PTO Generators - Any Favorites? #41
I also have a 200A xfer switch (inside the basement). I wasn't able to source a 60A female outlet so I simply have 30' of cord hanging on a hook outside the basement wall that will reach the tractor when needed.
The IEC60309 plugs/connectors support 60A, e.g.,
IEC60309 16A 3 Pin 220V-250V 50/60Hz 3P 6h 2P+E Waterproof IP44 CEE/IEC Femal... | eBay
They are not cheap, but they are quite robust and have features to make them weather resistant. If you are hooking it up to a cable, can I suggest "Mine rated" cables, e.g. type W? The cables are oil/water/sunlight resistant. (E.g. Nassau cable)
Personally, I assume that if I'm hooking up the house, the weather isn't great.
The connectors and cables often turn up used, at significant reductions in price.
All the best,
Peter
New/Unused Pallet Forks (A54865)
New/Unused Pallet...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A56129)
2013 KENWORTH T680...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2024 New Holland Skid Steer (A52377)
2024 New Holland...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2012 TEXAS BRAGG ENTERPRISES 24+6 T/A GOOSENECK TRAILER (A55745)
2012 TEXAS BRAGG...
