PTO Generators - Any Favorites?
   / PTO Generators - Any Favorites? #11
Winco 10kW. Three houses, barn requires mobility. 0.56 gallon per hour with the B26.
107gallon tank just put into service.
Even with best precautions, running a generator inside is risky. Do have a Miller Bobcat welder/generator in the shop, exhaust routed outside. Run with garage door open and fans running when operating. Always risky.
That's an interesting gen cover Mr. Smokeydog. Very thoughtful...
And that's another Winco vote.
You'll like that tank. It sure makes life a lot simpler to just fork it on the trailer and go get 100 gal of red diesel.
   / PTO Generators - Any Favorites? #13
If you heat with fuel oil, you usually have a sizeable supply on hand. Mine would run my diesel generator for a month if necessary. Any longer than that, electricity will be the least of your problems.
That's what we did with my elderly mother. She had an oil burning furnace with a 500 gallon tank. #2 fuel oil is the same as #2 diesel. We plumbed the generator into the furnace line.
   / PTO Generators - Any Favorites? #14
I wish I could do the same with my 1000 gal. tank. The generator is out in the barn and piping fuel out there isn't practical. Instead, I built this caddy with 4 pneumatic tires that will roll over rough ground. It's a 30 gal. barrel with a cordless tool battery powered pump:
   / PTO Generators - Any Favorites? #15
View attachment 1858634 View attachment 1858632 View attachment 1858633
That's a really clever setup!
I'm curious; How did you craft the battery holder? From an old tool? How stable is it?
All the best,
Peter
   / PTO Generators - Any Favorites? #16
All the best,
Peter
Battery adapters for most cordless tool brands are available online:
Dewalt:
Milwaukee:
Ridgid:
Makita:
And many others. Just Google "cordless tool battery adapter."
I use the DeWalt adapters for many applications and they work very well. Just be careful not to short the leads with a battery connected.đź’Ą
   / PTO Generators - Any Favorites? #17
@bdhs Thanks! That would have saved me a bunch of effort on my fuel pump. I put a 120V to 12V power supply into a sealed enclosure with sealed switches. Way too complicated. I think that is I will repurpose that power supply for another use and use your solution.
All the best,
Peter
   / PTO Generators - Any Favorites? #18
What's your Dewalt battery voltage? I love the idea, but don't want to put 18 volts to a 12 volt pump.
   / PTO Generators - Any Favorites? #19
Checkout the grey item to the right of the battery; I think @bdhsfz6 used a voltage regulator off of some vehicle.
All the best,
Peter
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
2011 FORD F-250 Crew Cab 4X4 Pickup Truck (A53422)
2011 FORD F-250...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
Informational Lot - Shipping (A55302)
Informational Lot...
