PTO generator.
/ PTO generator. #1
JTS51
Hudson WI
Bobcat 5610D, ASV PT70, Case 850L, JD 5100M
Has anybody used a PTO generator with their 5610? If so, how did it work out for you?
/ PTO generator. #2
Huh? What does a pto generator have to do with a certain brand of tractor?
/ PTO generator. #3
Because it is a hydraulic pto and there may be an issue with driving a generator. I have also wondered if it is possible.
/ PTO generator. #5
Hydraulic pto? So that is a toolcat specific thing?
Regardless, the toolcat - like other machines with a pto - should have a rated HP for the pto. Generators should also have a 'minimum HP' rating required. As long as one keeps the generator size below the tractor's rating, why would it have issues?
Does bobcat say one cannot run generators with it?
/ PTO generator. #6
There is no direct drive for the 3pt pto as it is a hydraulic motor driven by fluid. It is rated for 25hp. I have also searched generators driven by skidsteers and never came up with a good answer.
/ PTO generator. #7
The good answer is, IF the pto can hold a constant speed then it will work, and I bet it will.
As long as you realize that it will cost more in fuel to run the generator, with a "hydraulic powered" pto rather than a direct drive powered pto.
SR
/ PTO generator. #8
why would anyone use the Toolcat to generate power, it would be far cheaper to have a stand alone generator on gas or diesel plus no wear and tear on the Toolcat, just my opinion
/ PTO generator. #9
Please tell me where "I" can buy an 1900 RPM 15kw diesel "stand alone" generator for $1.200.00?? How about at double that price??
That's what I paid for my Winco pto generator and I'd have the tractor anyway...
SR
/ PTO generator. #11
Convenience, cheaper price and not another engine to maintain.
We rarely have long power outages here, so I know the Toolcat will start and it would be easy to hook up to the PTO generator.
/ PTO generator. #12
........ SR
Exactly! This is what i was saying. Why would there be any reason to think it won't work? It is a standard 540 PTO with no restrictions given by Bobcat. If it was somehow not as reliable or didn't work as well as a mechanical PTO, wouldn't the manufacturer state that?
MIRRORS, MARKER LIGHTS, SWITCHES (A64276)
MIRRORS, MARKER...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
3142 (A63117)
3142 (A63117)
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
