PTO generator.
/ PTO generator. #1
JTS51
Hudson WI
Bobcat 5610D, ASV PT70, Case 850L, JD 5100M
Has anybody used a PTO generator with their 5610? If so, how did it work out for you?
/ PTO generator. #2
Huh? What does a pto generator have to do with a certain brand of tractor?
/ PTO generator. #3
Because it is a hydraulic pto and there may be an issue with driving a generator. I have also wondered if it is possible.
/ PTO generator. #5
Hydraulic pto? So that is a toolcat specific thing?
Regardless, the toolcat - like other machines with a pto - should have a rated HP for the pto. Generators should also have a 'minimum HP' rating required. As long as one keeps the generator size below the tractor's rating, why would it have issues?
Does bobcat say one cannot run generators with it?
/ PTO generator. #6
There is no direct drive for the 3pt pto as it is a hydraulic motor driven by fluid. It is rated for 25hp. I have also searched generators driven by skidsteers and never came up with a good answer.
/ PTO generator. #7
The good answer is, IF the pto can hold a constant speed then it will work, and I bet it will.
As long as you realize that it will cost more in fuel to run the generator, with a "hydraulic powered" pto rather than a direct drive powered pto.
SR
/ PTO generator. #8
why would anyone use the Toolcat to generate power, it would be far cheaper to have a stand alone generator on gas or diesel plus no wear and tear on the Toolcat, just my opinion
/ PTO generator. #9
Please tell me where "I" can buy an 1900 RPM 15kw diesel "stand alone" generator for $1.200.00?? How about at double that price??
That's what I paid for my Winco pto generator and I'd have the tractor anyway...
SR
/ PTO generator. #11
Convenience, cheaper price and not another engine to maintain.
We rarely have long power outages here, so I know the Toolcat will start and it would be easy to hook up to the PTO generator.
/ PTO generator. #12
........ SR
Exactly! This is what i was saying. Why would there be any reason to think it won't work? It is a standard 540 PTO with no restrictions given by Bobcat. If it was somehow not as reliable or didn't work as well as a mechanical PTO, wouldn't the manufacturer state that?
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2014 Kenworth T400 T/A Kill Truck (A64194)
2014 Kenworth T400...
2000 MACK RD688S DUMP TRUCK (A64278)
2000 MACK RD688S...
SKID STEER FORKS (A64553)
SKID STEER FORKS...
Alligator Statue (A64557)
Alligator Statue...
78in Heavy Duty Hydraulic Grapple Rake Skid Steer Attachment (A64553)
78in Heavy Duty...
