PTO generator
/ PTO generator #301
Fred, My point was that a $400 VFD, or $100-$200 on Y start, Delta run (if you have the right motor), will be way cheaper than the oversized generator needed to start it the way it is. Not only in initial cost but in fuel savings.
/ PTO generator #302
Can this start a motor under load with less source amperage??
/ PTO generator #303
Just picked up my John Deere 10kw PTO generator the other day that I ordered a couple of weeks ago. Little pricey, but one solid unit. Nice 3pt platform it is mounted on.
/ PTO generator #304
Who are good manufactures of PTO generators? Who should I stay away from?
I am looking for a 10KW unit. What are some good features to look for?
Harbor Freight has this unit
Search results for: 'pto generator'
Tons of these units on ebay, are they worth it?
New 15KW PTO Driven Generator Cat 1 3pt 25 HP Rating | eBay
Diesel Power Torq PTO Generator 16KW Max w 3 Point Hitch New | eBay
How about Northern Tool product?
NorthStar PTO Generator — 7200 Watt, 14 HP Required | PTO Generators| Northern Tool + Equipment
Thanks for your help.
/ PTO generator #305
The Harbor Freight, ebay, Torq, and Rural King are all the same unit that is made in China. I bought mine from Rural King for around $ 1,160.00. Haven't used it except for testing it out but seems like a solid unit.
/ PTO generator #308
Thanks guys, it looks like it is back ordered....:mur:
This looks like a great deal hopefully they are in a container on the way to the USA.:boat:
The pto shaft that was sent with my generator was severly short. After contacting Rural King they investigated and called manufacture. Manufacture said the sent some too short and will send me the correct one. Still waiting after 3 weeks. Otherwise, no complaints.
/ PTO generator #309
Watch the Rural King site cause when they get them in they sell out fast.
/ PTO generator #310
I am sure it will be perfect for a BX 2200, all of my stuff I had to cut a lot of the shaft.
/ PTO generator #311
Around here this is no longer possible since they addition of 5% biodiesel, so if you need long term storage diesel I have heard that you can possibly get straight diesel for standby generators. They are now recomending a 30-60 day turnover of the diesel fuel stock.
David Kb7uns
Whos got that 5% biodiesel added here in Oregon? I have Wilcox&Flegal's diesel delivered and it supposedly doesn't have that 5% mix, so should be good for at least a year or more.
/ PTO generator #312
Yup. Both methods can slow the progression to full speed, and as a result reduce the power demand at any time interval during that startup time period...even under load.
/ PTO generator #313
That just doesnt compute. Where does the torque to run the load come from with reduced power being supplied to the motor ... :lightbulb: I guess, for the VFD, more efficiency by feeding it at an only slightly higher than synchronous frequency as it accelerates?
larry
/ PTO generator #314
Think of it this way: You can allow the motor twice the time to accelerate to full speed.
Beacuse you have a slower acceleration, you need less torque.
Here's a non electrical genealized example:
Truck 0-60mph in 10 sec. 200HP required
Truck 0-60mph in 20 sec. 100HP required
/ PTO generator #315
That is accelerating against only inertia. Not a good analogy since required torque is reduced for slower accel. Actual loads often require almost the same torque regardless of speed. For instance - lifting a weight.
larry
/ PTO generator #316
VFD use on motors works very well. When starting the amps ramp up instead of surging when driving centrifugal pumps. If you were starting a load that needed more torque then the VFD would need to be configured differently to allow for the torque needed o start the load. We have some single phase services that power 60 HP 3 phase motors. If you are going to use a VFD to drive a 3 phase motor on a single phase service then the VFD has to be oversized. Its best to check with the manufacturer on what the recomended size to use.
/ PTO generator #317
larry
Sorry you didn't like my simplified analogy. I could explain it from an electrical-physics point of view, but if you don't get it from my simplified mechanical example, you will only get more confused. I think all can say useful at this point is, trust me. Both methods are used in industry everywhere-everyday. It's a proven method.
/ PTO generator #318
Please explain it from an electrical-physics point of view. The reason the simplified analogy didnt work is it doesnt pass muster on the Physics side by differentiating between driving a load, and encountering a load due to acceleration.
larry
/ PTO generator #319
Thanks for all the great advice. All of you guys have been very helpfull in getting me educated. Now I just have to do some shopping.
/ PTO generator #320
From state website
In compliance with Oregon's Renewable Fuel Standard [Ref. Oregon Revised Stature (ORS) 646.921 and ORS 646.922] All diesel fuel sold or offered for sale in Oregon must contain a minimum of 5 percent by volume biodiesel, creating a B5 biodiesel blend, except for 1) railroad locomotives, 2) marine engines and 3) home heating applications.
David Kb7uns
NEW IDEA 2R CORN PICKER (A64278)
NEW IDEA 2R CORN...
Buckhorn Poly Bulk Seed Box (A66408)
Buckhorn Poly Bulk...
SURE FIRE 5.3GPM LIQUID FERTILIZER UNIT TOWER (A64278)
SURE FIRE 5.3GPM...
2015 BMW X1 SUV (A64557)
2015 BMW X1 SUV...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
