PTO generator selection help
   / PTO generator selection help #121
I bought a 25kw continuous 50kw surge 1800 rpm Generac PTO unit in 1999 in preparation for Y2K which never happened.
After reading this post I need to ask if there is a real advantage of 1800 rpm versus a 3600 rpm PTO generator?
90cummins
I believe that 1800rpm generators are usually quieter, and often, but not always, more efficient on a BTU/kWh basis. (Frictional losses in an internal combustion engine generally tend to increase with rpm.)
All the best,
Peter
   / PTO generator selection help #122
I personally think the only advantage that you have is the required speed of the generator. Half the speed does reduce wear and possibly allows the tractor to run a lower RPM. I don't think there are any significant changes in the quality of power from a generator until you get into inverter units.
   / PTO generator selection help #123
I have heard that brushless generators have really dirty power. At least one oscilloscope trace seemed to verify that. The sine wave looked halfway to a squiggly sawtooth. That makes no sense to me, but maybe I don't understand how rotating field generators work.
   / PTO generator selection help #124
Based on my experience, I would not make that particular assertion. Clean, or dirty power arises from lots of sources; choices in winding design, choices in voltage regulation, choices in rotor design/construction, and of course maintenance and tuning.
To the extent that brushes aren't in good shape and in the commutator design is not good, you can get a lot of noise out of a brushed design.
I think a lot of this comes down to the quality of the pieces of the generator and the overall construction.
I have a couple of inexpensive generators that I use to power things like 120V tools in remote locations. Since they are just running a motor, often a cheap motor, I don't sweat the power quality ever. However, I have looked and the power was actually very good, but all it takes is a diode or a capacitor or a regulator to start dying and power quality goes out the window.
Running pricey home devices that are electronic? I think that is a different story; test and measure, and keep testing and measuring. As someone famous once said "trust, but verify", and for electronics, I would also add "use as many surge and EMI protectors as you can", as every little bit helps.
All the best,
Peter
DOOSAN G25KW GENERATOR (A53843)
DOOSAN G25KW...
White Metal Roof Panels (A55758)
White Metal Roof...
New/Unused Quick Attach Pallet Forks (A54865)
New/Unused Quick...
2006 International 9400i (A55302)
2006 International...
2016 Chevrolet Malibu Sedan (A55758)
2016 Chevrolet...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
