PTO Generator on 1920 Diesel,,,,
   / PTO Generator on 1920 Diesel,,,, #12
Those who add up watts will be bitten in the backside with VAR’s and wonder why the 4800 watt load keeps tripping the breaker on the 5000 watt generator .
correct.. you can't simply add them up, but they are still inter-related.
Most people don't understand motor start loads either, and why some air handler / compressor systems have a delay built in to stagger starting loads.
   / PTO Generator on 1920 Diesel,,,, #13
Fuel consumption depends on generator load About 1.5 TO 2.5 GPH.
   / PTO Generator on 1920 Diesel,,,, #14
I would hope that your little Ford wouldn't use that much fuel on a small generator, it will vary with the load but you should be under a gallon/hour. My generator is a 25 KW but under normal use I average about a gallon / hour with either 80 HP or 65 HP on it, I do run the big one in the economy pto speed.
   / PTO Generator on 1920 Diesel,,,, #15
Bottom line, fuel usage is based on generator electrical load.. can't dodge physics. there is a certain amount of energy in the fuel, and there is a physical conversion from hp to wattage.
No free meals.
2005 John Deere 330C LC (A55272)
2005 John Deere...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2012 International Prostar (A56438)
2012 International...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
