PTO Generator on 1920 Diesel,,,,
   / PTO Generator on 1920 Diesel,,,, #12
Those who add up watts will be bitten in the backside with VAR’s and wonder why the 4800 watt load keeps tripping the breaker on the 5000 watt generator .
correct.. you can't simply add them up, but they are still inter-related.
Most people don't understand motor start loads either, and why some air handler / compressor systems have a delay built in to stagger starting loads.
   / PTO Generator on 1920 Diesel,,,, #13
Fuel consumption depends on generator load About 1.5 TO 2.5 GPH.
   / PTO Generator on 1920 Diesel,,,, #14
I would hope that your little Ford wouldn't use that much fuel on a small generator, it will vary with the load but you should be under a gallon/hour. My generator is a 25 KW but under normal use I average about a gallon / hour with either 80 HP or 65 HP on it, I do run the big one in the economy pto speed.
   / PTO Generator on 1920 Diesel,,,, #15
Bottom line, fuel usage is based on generator electrical load.. can't dodge physics. there is a certain amount of energy in the fuel, and there is a physical conversion from hp to wattage.
No free meals.
2017 Ford F-250 Pickup Truck w/ Liftgate (A56858)
2017 Ford F-250...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
SDLL60 Loader (A55272)
I.H. LARGE M PEDAL TRACTOR (A58374)
I.H. LARGE M PEDAL...
HUSQVARNA RIDING MOWER (A52708)
HUSQVARNA RIDING...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56436)
Bulk Lot of NEW...
