Generator PTO generator feedback
/ PTO generator feedback #61
I'm not ready to call the chinese standalone engine equal to one I might see in a modern 1st or 2nd tier tractor brand....
soundguy
So, just to be clear, you think these diesel engines might be throwing away 15 or 20% more fuel than a tractor engine?
larry
/ PTO generator feedback #62
The unit is setting at my hunting camp at present and the name on the cover escapes me, Sensee or something strange like that. This is one of the Chinese units we see so many of these days and so far we only have 30+ hours run time on it. Not sure what the long term is going to be. If we get as good of service out of it as we have the '89 Coleman 4kW it will be a good value.
I bought a 6.5KW Chinese generator this year as well. I can juggle the load and run the water heater where I could not with the 4KW Coleman Power mate that I have had since 1991.
The Power Mate has been a very reliable unit starting on the first or second time every time. I just had to use it for a 6 day outage we had and I run more than 35 gallons of gas through it(runs 2 hours on a gallon). I was a head ache because it only has a 1 gallon tank.
The Chinese unit has a 3.5 gallon diesel tank mine is an Aurora and is the same as an Optigenerator. I did a break in run for 20 hours and then adjusted the valves and changed the oil to Synthetic. We will see if it holds up well.
/ PTO generator feedback #63
I guess you and I have very similar histories. Got my Coleman just 2 years before you, (the engine and gen head are painted green), I have been amazed at how well this unit has held up and I also have bragged about how dependably it has started and run over the years. With it I had to dump everything to run the water heater since the element is rated at 4.5kW, but it would do enough heating in a couple of hours to let us get decently warm showers on cool mornings.
My Chinese is due for an oil change. Broke it in and went through an outage that was just short of 24 hours with 15-40 Rotella, though the company guy recommends straight 30w. I am contemplating synthetic though. What kind did you use? By the way, did your valves need much if any adjusting? Guess I need to plan on checking mine.
/ PTO generator feedback #64
I never tried the water heater with the coleman, but I will say I have not had to do anything to that generator except change the oil(mine is green too).
I used 15w-40 Rotella for break in oil and I used 5w-40 Rotella Synthetic when I changed at 20 hours.
The valves were only slightly out of adjustment.
I did find that the oil filter had a small tear in it probably from the factory but there were only a few metal particles on the filter screen.
I have the generator manuals on PDF for my Genset if you are interested in a copy send me a PM. They may not be exact but might be good reference.
/ PTO generator feedback #65
Maybe thats my problem I'm stupid I have been trying to figure out whats wrong for years(I spent all that money and you solved it for free). Thanks. :D Thew other thing that I find is that I need my tractor at the same time I need the generator. The only thing that will fix this need is a stand alone generator or a reeeeeeeeally long cable.:)
Get the wife a tractor!:D
/ PTO generator feedback #66
larry
Like I said in a previous post.. I'm not ready to come to a conclusion either way, and .. if youd have read my earlier posts.. which you obviously didn't???.. you'd see that i had said that I would bet the fuel usage would be close anyway.
And yes.. I do expect a cheap small engine to not be as good as an expensive large engine.
My tractor engine costs a few thousand bucks in crate form.. I suspect the rice generator engine doesn't.. I expect a long service life out of that tractor engine.. multi-decades of rated speed and rpm and hp output use. I don't expect multi-decade simialr use out of what amounts to a diesel lawnmower engine. But like I said.. I'd reserve judgement till I saw some actual DATA...
soundguy
/ PTO generator feedback #67
I went the other way around as I didn't have a tractor at the time. I have a 15KW standalone natural gas generator at the house and a 45KW propane which runs the ranch. Both with automatic transfer switches. The neighbors can ask to borrow them all they want, but they better have a long cord as neither is portable.
/ PTO generator feedback #68
While the larger engine may burn a tad more fuel just for differences in spinning mass.. compairing diesel usage to diesel usage on the 2 gennies at the same electrical load level over the same time period.. I'd still lay my 2$ on them having such close fuel usage as to be negligible. The convienience factor, however, as you pointed out, is plenty enough to justify either combination as the owner see's fit.
soundguy
I wouldnt. The pumping and friction losses in the bigger engine will be a factor as you say. But more importantly, the standalone doesnt have the PTO transmission loss exhibited in the tractor and the genny gearbox. The end to end connection of engine to generator in a standalone approaches 0% loss of power. So, with near equal efficient engines and generators the standalone will be much more sparing of fuel use.
larry
soundguy
larry
soundguy
I read your previous posts. Odd that you cant tell... unless you didnt read mine. The inherent advantage in mechanical efficiency offered by the standalone setup is so great it will be hard to get back with a better engine in the disadvantaged unit [tractor system/+pto].
So, to repeat: Just to be clear, you think these diesel engines might be throwing away 15 or 20% more fuel than a tractor engine?
larry
/ PTO generator feedback #69
I was reading these posts and really do not have an opinion...but do have a story about the security of your generator.
Talked to a fella out in western Ky after all the ice storms last year. He was using his small generator to power the heating in his home. Late one night after going to bed he said it kept getting colder and colder....the genny was still running so he thinks maybe a bad connection or something. Went out to check his connections and generator was gone but someone had left a nice running pushmower sitting in its place. Moral is if they want it bad enough they will get it.
/ PTO generator feedback #70
Had the same basic thing happen to a guy during the outage after Rita which actually knocked power out longer than Katrina for us. These thieves were really gutsy, they cranked the guy's riding mower then jerked the generator while he was watching the late edition of the news. As the story was told, when the power went out he instinctively listened for the engine sound which he heard, so he grabbed a light, got dressed and put on shoes/boots all before he eased out to find out why the output had stopped even though the engine was still running. This is why I use a locked security cable to anchor my unit to the 2-7/8ths tubing that serves as the carport post. They will have to work at getting it loose or bring some high quality cable cutters with them, which they may one day because this kind of theft is getting more pronounced with every year.
/ PTO generator feedback #71
Much has been posted questioning the long term durability of the Chinese Diesel gensets which I guess would also apply to typical backup units like my old 8hp Briggs powered Coleman Powermate though I am not sure why that has gotten so much attention. We are comparing air cooled engines to water cooled tractor engines, of course there is going to be a longevity difference between the two types of engines. These units are not being used as "prime power" units expected to run 24/7 for years under near max capacity. They are used for temporary power in cycles that may last for an hour, a few hours, a day, or maybe a week. In a worst case one might have to go for a couple of weeks. If my Chinese unit gives me 20 good years as the Coleman, which still runs well, has then I will be well pleased with the investment.
I do not envision going to the extreme that my neighbor did to have backup power after the Katrina/Rita episode. He bought a 40kW Cummins powered 1800 rpm prime power rated unit. Built a house for it etc. During our most recent extended outage he made power for just over 24 hours on 0.9 gallons per hour. Given his investment, I could run my tractor for many weeks even if it were to burn 3.0 gallons per hour doing so, and still have money left over. As long as I could get diesel anyway. One of the big issues we had after Katrina was even getting fuel and gasoline, which has been the driving force behind seeking low consumption alternatives. I now have a diesel unit that only burns half as many gallon per 24 hours as the gas unit I have to run the same basic load. In addition to that it has enough reserve capacity to run the water heater if necessary.
Maybe this summer I will get a chance to run the PTO and the Chinese unit for a few hours each tied to the 5kW test load I have and measure the respective fuel consumption. Rest assured, once done I will be glad to post the results to this thread.
/ PTO generator feedback #72
These Chinese diesel standalones are intriguing and maybe the wave of the future...
But talking about longevity, we know diesels outlast gassers in general due to their slower turning and HD construction required for the greater compression pressure.
These new diesels are turning 3600 rpm's, way hotter than any diesel we are accustomed to. Basically making them high pressure "whiz-bangers" made with CHI materials and engineering.
It will be interesting to see how they compare to gassers of the same output.
Not knocking them, even if they were just equal to the gasser in service life, and cost about the same. With them being diesel, for me just for the fuel stability issue they would be my first choice (between the standalones that is).
Here are the diesel standalones you really want. If you can afford them :)
Norpro | A Whole Lot More Than A Diesel Generator Manufacturer
JB.
/ PTO generator feedback #73
Points of info and curiosity ... Is that standalone diesel setup a direct 1:1 drive:driven rpm, or is there a gear reduction? What is the rpm they run at?
Thanks!,
larry
/ PTO generator feedback #74
Thanks!,
larry
The ones this size are direct drive 3600 rpm units which I agree is right at the limit of diesel combustion speed.
/ PTO generator feedback #75
Interesting point. I wonder if there is a reduction in efficiency running diesel at this speed? I wonder if it is of similar magnitude to the gearbox losses of a pto unit? More? Less?
/ PTO generator feedback #76
I have posted many times about this but here is what I ended up with. I have a $1000 Troy Build Genny that has a 13 HP engine. Starts 1st or send pull every time and puts out 8550Watts. I ran it for 8 days once 24/7 except to change the oil every other day. I even added fuel while it was running. I know call the safety police. It has also served many 3 day outages and a few 1 day outages. Probably ran for 20 full days since 2003 when I bought it.
Anyway it used 9 gallons per day. I had trouble getting gas so now keep 100 gallons on hand and just cycle it though my cars after 6 months or so.
My house has propane heat and hot water. It will run everything we need including the well pump, 2 fridges, 1 deep freezer, lights, tv's, micro, even the stove. We have also done wash but had to hang the stuff up to dry since our dryer is a electric unit. It will not run our AC but I have a old window unit I have moved up to the bedroom for a 3 day outage when we got hit by a tornado in 100 deg heat of august.
Would I like a PTO genny? Sure. I would only use it if needed to do the laundry or run the Central AC. The Troy Built has been top notch and if it dies I will buy another.
Chris
/ PTO generator feedback #77
My father used to be a diesel injection pump specialist for the army. He explained it to me. In the old days of diesels the limiting factor was minimum fuel metering to the engine (for idle speed). There were not machines able to manufacture small injection pump as later on. In example spark erosion manufacturing was invented and made practical much later. Therefore there was a smallest practical volume of the cylinder. I only vaguely remember that the minimum was more than 500 ccm (30 cin) or usual size closer to one liter (60 cin). So the reciprocating forces were large limiting the speed to about 1800 - 2500 rpm. Later on much smaller injection pumps were manufactured allowing for smaller volume of the cylinder and faster running engines that would last because of smaller cylinder with shorter stroke translates to lower median piston speed.
Today's high revving diesels are hard to tell apart from gassers. If you have driven one you would love them.
/ PTO generator feedback #78
Id say less. There are tricks to improve on it - injection timing, multi point injection, and higher injection pressure thru small nozzles for better atomization. Still, for best fuel economy I think yould want one designed around an 1800 rpm direct drive setup using the 4pole alternator. This would let you get nominal speed right at a long-stroke-engine torque peak so it would hold speed at full load extremely well.
larry
/ PTO generator feedback #79
larry
True, those tricks all improve efficiency. However they all come at a cost. It seems unlikely they would be included in a budget portable CHI that is brought to market with extreme sensitivity to price/margin. I have to wonder if the budget diesel gens are designed to achieve the necessary 3600rpm at the lowest cost, with little thought to optimizing fuel efficiency. Just thinking about theoretical vs reality.
/ PTO generator feedback #80
Just checked some dyno test on internet. Two wheel drive cars deliver about 7% less power to the road than the engine produces. It includes all transmision and differential gears and tire deformation and friction to the road. It might give you some idea about losses of generators with gearboxes. My guess is that the gearbox makes very little difference in efficiency. Probably the cooling fan uses more power that the gear. Look at it this way. If the gear would lose (all loses are turned into heat) let say 10% of engine power to deliver 10kW it would run red hot.
2022 EZ-GO ELITE...
NEW Wolverine SP-15-84W Snow Blade (A62679)
NEW Wolverine...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2011 WESTERN STAR  4900SA  SLEEPER (A65643)
2011 WESTERN STAR...
2019 CENTEX TRAILER 16' COOL DOWN TRAILER (A65643)
2019 CENTEX...
2009 Ford F250 (A66408)
2009 Ford F250...
