PTO from hydraulic motor
/ PTO from hydraulic motor #1
BrisMatt
Australia
JD 455
I have a JD with auxillery hydraulic ports but without a rear PTO. You can buy a rear PTO kit for this machine but they are no longer sold in Australia and are very expensive. I was thinking about using the machines aux hydraulic port and control valve to run a hydraulic motor that acts as a rear PTO. I have found a few motors at surplus centre that run about 500-600 rpm and provide the adequate torque for my purposes. A link to a motor I had in mind is here.
I was just wondering has anyone attempted this before?
And what coupler is required to fit the pump shaft to a PTO shaft.
Matt
/ PTO from hydraulic motor #2
What is the hyd pressure on your pump? Do you have enough hyd flow to run that motor efficiently?
* Dynamic Model Number JPPS-125 H4-K-P
* Displacement 7.7 cu.-in./rev.
* Pressure
1400 PSI Cont.
2000 PSI Int.
* Torque
1354 Cont. in.-lbs.
* Speed
512 RPM Cont.
* Flow
18 GPM Cont.
I believe Surplus Hyd also has the splined coupler
/ PTO from hydraulic motor #3
5 GPM and 7.7 cu in, speed of hyd motor would be about 150 rpm
Looks like I have mixed up my l/min with gpm.
The manual states the charge pump flow is 17.0 L/min (4.5gpm) observed
and the relief valve 1066 psi
its a JD 455. They operate FEL's from these ports usually.
Are these numbers too low to have a rear PTO with an rpm close to 540rpm.
/ PTO from hydraulic motor #6
No - but they are too low to have a rear PTO with any kind of power behind it at that speed.
4.5 GPM of flow run thru a motor with a displacement of 1.92 cu. in. yields 541 rpm
but .... a motor with a displacement of 1.92 cu. in. ..... running at a pressure of 1066 ..... only yields 326 in lbs of torque (which is a little over 27 foot lbs, or almost 37 newton-meters, of torque :()
A larger displacement motor will get you more torque (some) at the same pressure .... but that will result in a slower speed, given your flow (gpm)
I think you really need more flow and pressure to do any substantive work :eek:(as in a rear PTO)
Yes that equates to about 3hp.
I do have a mid PTO which I dont require. It spins at 2000 rpm to run a mower deck. Perhaps a new pump hooked up to that to run a bigger motor. I see surplus centre has PTO motors that require about 20gpm.
/ PTO from hydraulic motor #8
Yup :(
I'm actually looking at doing that very thing myself - to drive a hydraulic pump to power a hydraulic motor to run a snowblower - see my thread here:
Convert Rear PTO Snowblower to Front Hydraulic
It's not that they necessarily require it, it's that they are capable of using it ....
Think about it this way:
A particular flow (in GPM) thru a hydraulic motor (under no load) of a particular displacement will determine the speed of rotation.
When the motor (and as a consequence, the hydraulic pump) encounters resistance, pressure builds - which provides the force/torque/power to accomplish work.
Where can I find a coupling to connect a hydraulic motor to the flywheel of my Yanmar Diesel engine out of my JD 455?
Matt
