LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,796
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Many of the European model tractors have multiple speed PTO's and many also have a selector to have a ground speed or transmission powered pto. The ground speed is powered from the final drives so it has a rotational speed that is proportional to the rear axle speeds increasing as you go higher in the gears. This allows the pto driven implements to have a ground speed drive that matches up with the tractors. Ie. in first gear the pto output shaft is turning very slowly and the speed increases as you go up in gears till you get into your highest gear at which point it is turning the fastest.
Very few North American models have it installed.
