PTO driven log splitter
   / PTO driven log splitter #11
It was pointed out to me that in reality the quoted cycle time of a splitter is a bit of a red herring because logs are normally split long before the ram has gone on its complete outward journey. Even with a 20 second cycle splitter, if a log is split after, say, four or five seconds, the ram should only take the same amount of time to return.
   / PTO driven log splitter #12
</font><font color="blue" class="small">( It was pointed out to me that in reality the quoted cycle time of a splitter is a bit of a red herring because logs are normally split long before the ram has gone on its complete outward journey. Even with a 20 second cycle splitter, if a log is split after, say, four or five seconds, the ram should only take the same amount of time to return. )</font>
You don't split much elm, do you? /forums/images/graemlins/wink.gif
--->Paul
   / PTO driven log splitter #13
</font><font color="blue" class="small">( You don't split much elm, do you? )</font>
You do like your herring up there in Minnesota, don't you Paul? I used to live there too, and the elm with which I'm familiar doesn't really "split". Oh yes, you can argue that pieces of it come off the splitter - eventually. But in actuality there's more tearing done - than actual splitting. Down here elm (and willow) go on the brush pile, not in the fireplace.
//greg//
   / PTO driven log splitter #14
Some woods, yup, like elm, are stringy and you have to run the ram right to the wedge. I keep a hatchet handy to whack the fibers that keep the pieces together. My homemade 4x36 splitter with a 13 gpm pump takes 17 seconds out and 15 seconds back no load. It's boring. Maybe when I'm 75 it'll seem just about right.
Jim
   / PTO driven log splitter #15
Nah, Jimmy, I don't think so, not if you've still got your health. I'm 66 and when I'm outside workin', I want to be WORKIN'. /forums/images/graemlins/grin.gif
Seriously, though, your post confirms my point; the mathematics of cycle times are pretty much immutable and if you want a cycle time that doesn't have you waiting around to load the next round, you have to have sufficient hydraulic pump output to move the ram at a reasonable rate; if you have a larger cylinder, you just can't get that with the output of the smaller CUTs.
BTW, where in Western Mass are you? I live year round South of Boston but have a weekend/summer place w/30 acres of woods in Alford, right on the NY state line.
Regards,
   / PTO driven log splitter #16
You do like your herring up there in Minnesota, don't you Paul? //greg// )</font>
Actually I'm in the pocket up here that like our bratwurst & beer. /forums/images/graemlins/smile.gif
Most wood splitters around here have 2 pieces of square stock welded vertically on the push ram. The strips push the wood past the splitting edge.
I did the elm with a maul & 5 wedges. Best was when it was about 10 degrees out.
It is stringy stuff, but it is _the_ hardwood around here, burns well, and there is so much of it after the Dutch Elm Disease.
--->Paul
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2018 PETERBILT 579 SLEEPER (A51222)
2018 PETERBILT 579...
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
