PTO driven log splitter
/ PTO driven log splitter #1
Big_Charlie
Fulton, KY
Montana R4944HST
Does anyone here have any good experiences to relate with PTO driven log splitters? Where did you find one??
/ PTO driven log splitter #2
Yes. Tractor Supply. It's a Huskee brand, operates both horizontal and vertical, runs about $645 retail - not including hoses. Click HERE.
//greg//
Looks like it runs off the hydraulics rather than running a pump off the PTO...smart.
/ PTO driven log splitter #6
</font><font color="blue" class="small">( Looks like it runs off the hydraulics rather than running a pump off the PTO )</font>
You're right, I misread the initial post; saw "PTO" but thought "TPH". Sorry
Regardless, I've always thought the PTO driven units to be redundant engineering. That is, why use an engine driven shaft to drive a detatched pump, when the engine is already driving the tractor pump by default ? Besides that - if the ground on which you're splitting is level enough, the type I'm using can standalone (in the horizontal position). If you need the tractor for something else, simply detach the two QD connectors and drive away.
//greg//
/ PTO driven log splitter #7
One reason is that unless your tractor hydraulic pump has pretty high output, you are going to have slow cycle times with any of the more powerful splitters. Ram power is a function of cylinder size and operating pressure.
For example, if your pump output is 7 gpm and you are using a 4" cylinder with a 2" rod, your extension time will be a bit over 11 sec. and your retraction time about 8.5 sec for a total cycle time of almost 20 seconds, which many people will find too slow for efficiency. A 4.5" or 5" cylinder would be even slower.
Thus, if you want to run a 20-30 ton splitter, unless you have a large tractor with a large capacity hydraulic pump, the only way to get reasonably fast cycle times is using a pto-driven pump.
Hope this helps.
/ PTO driven log splitter #8
</font><font color="blue" class="small">( For example, if your pump output is 7 gpm and you are using a 4" cylinder with a 2" rod, your extension time will be a bit over 11 sec. and your retraction time about 8.5 sec for a total cycle time of almost 20 seconds, which many people will find too slow for efficiency. A 4.5" or 5" cylinder would be even slower. )</font>
Think my pump is probably somewhere in the 8 gpm range, and I know I have a 4" cylinder. But from my hands-on experience, 20 seconds doesn't sound right. I actually throttle the tractor engine down to about 1100 rpm to get a comfortable working cycle speed.
//greg//
/ PTO driven log splitter #9
Greg_g: The math isn't too complicated.
A 4" cylinder has an area of about 12.57 sq.in. a 24" cylinder thus has slightly over 300 cu.in. volume.
An 8 gpm pump moves 1848 cu.in. /min or 30.8 cu.in./sec. The extension stroke would thus take about 9.7 sec.
My post had assumed 7 gpm, so your times are a bit faster than my original numbers, but not enough to make much of a difference. The point, however, remains the same, if you want the 10sec. + or - cycle times that one of the good Timberwolf splitters, for example, can produce, you are going to need to use a pump that can output about 15-16 gpm.
My B7800 (30 pto hp) only outputs about 9.5 gpm for both power steering and hydraulic system (about 7 or less for the hydraulics alone), and my memory is that you have to get up to the Kubota M Series before you get that kind of hydraulic pump output.
However, even my B7800 has plenty of pto hp to run a pump that will produce output much more than 16 gpm. On the homemade splitter that I am building, I am using a Barnes 2-stage that outputs 28 gpm at low pressures (up to about 750 psi) and about 7 gpm between that and 3000psi and only requires about 16 pto hp.
With a 5" cylinder I would only be using high pressure when dealing with a knot or twist or when using a 4-way or 6-way wedge on pretty large logs. I figure that my average cycle time (except perhaps when dealing with very large or difficult logs) will be under 10 sec.
All that said, if you are getting satisfactory cycle times using your tractor hydraulics that's fine and there is no reason to go to a pto-driven pump.
But, H**l, I always overdesign everything anyway; I built the doghouse for our newfie and black lab with 2x6 wall and ceiling framing, a partition that shelters the inner room from wind, snow and rain, and full insulation in walls, ceiling and floor slab. ...wife claims that it is better built than our house, which will be a comfort if she banishes me to it. /forums/images/graemlins/grin.gif
/ PTO driven log splitter #10
Big Charlie-
I had your same dilemna several weeks ago as I was going to buy both a new tractor as well as a splitter. I decided to go with a stand alone splitter just cuz I thought it would be more convenient in that I wouldn't have to get the tractor out if I decided I wanted to cut a big pile then split it another time. I also figured I could just pull the splitter out and set up an area wherever I wanted to do the splitting without having to tie up the tractor if I felt like timbering, cutting, and splitting all at the same time. This way I don't have to worry about removing the splitter to go into the woods to haul timer out... you get the idea. I guess it's all self preference. I was told by some experienced folks to just make sure I get a 20 ton minimum capacity unit. I'll probably split about 4 cords per year. I ended up with a nice unit for about $1500 that I can pull out into the yard or woods with my quad, enabling me to get into tight spaces if I need to. When I do get the chipper, I will go with a PTO driven unit however.
Good luck with the decision!!
/ PTO driven log splitter #11
It was pointed out to me that in reality the quoted cycle time of a splitter is a bit of a red herring because logs are normally split long before the ram has gone on its complete outward journey. Even with a 20 second cycle splitter, if a log is split after, say, four or five seconds, the ram should only take the same amount of time to return.
/ PTO driven log splitter #12
</font><font color="blue" class="small">( It was pointed out to me that in reality the quoted cycle time of a splitter is a bit of a red herring because logs are normally split long before the ram has gone on its complete outward journey. Even with a 20 second cycle splitter, if a log is split after, say, four or five seconds, the ram should only take the same amount of time to return. )</font>
You don't split much elm, do you? /forums/images/graemlins/wink.gif
--->Paul
/ PTO driven log splitter #13
</font><font color="blue" class="small">( You don't split much elm, do you? )</font>
You do like your herring up there in Minnesota, don't you Paul? I used to live there too, and the elm with which I'm familiar doesn't really "split". Oh yes, you can argue that pieces of it come off the splitter - eventually. But in actuality there's more tearing done - than actual splitting. Down here elm (and willow) go on the brush pile, not in the fireplace.
//greg//
/ PTO driven log splitter #14
Some woods, yup, like elm, are stringy and you have to run the ram right to the wedge. I keep a hatchet handy to whack the fibers that keep the pieces together. My homemade 4x36 splitter with a 13 gpm pump takes 17 seconds out and 15 seconds back no load. It's boring. Maybe when I'm 75 it'll seem just about right.
Jim
/ PTO driven log splitter #15
Nah, Jimmy, I don't think so, not if you've still got your health. I'm 66 and when I'm outside workin', I want to be WORKIN'. /forums/images/graemlins/grin.gif
Seriously, though, your post confirms my point; the mathematics of cycle times are pretty much immutable and if you want a cycle time that doesn't have you waiting around to load the next round, you have to have sufficient hydraulic pump output to move the ram at a reasonable rate; if you have a larger cylinder, you just can't get that with the output of the smaller CUTs.
BTW, where in Western Mass are you? I live year round South of Boston but have a weekend/summer place w/30 acres of woods in Alford, right on the NY state line.
Regards,
/ PTO driven log splitter #16
You do like your herring up there in Minnesota, don't you Paul? //greg// )</font>
Actually I'm in the pocket up here that like our bratwurst & beer. /forums/images/graemlins/smile.gif
Most wood splitters around here have 2 pieces of square stock welded vertically on the push ram. The strips push the wood past the splitting edge.
I did the elm with a maul & 5 wedges. Best was when it was about 10 degrees out.
It is stringy stuff, but it is _the_ hardwood around here, burns well, and there is so much of it after the Dutch Elm Disease.
--->Paul
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
2016 Kia Forte Sedan (A61574)
2016 Kia Forte...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Adams High Clearance 5 Ton Spreader (A63688)
Adams High...
2007 Ford F-250 Crew Cab Pickup Truck (A61573)
2007 Ford F-250...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
