PTO disengage while runing
/ PTO disengage while runing #1
zenonmb
Fiat 600E 1977
I have an old fiat 600, from 70’s that after running 20 mins with a lawn mower, the pto disengage.
Also noticed that when trying to engage pto it makes noise( gears noise).
So it sounds like two problems.
Not easy pto engagement and pto disengagement while running
With the tractor stopped, if i press the clutch to the end pto is released, i can move it by hand. But when running something changed inside and pto even with full clutch, it is still stucked.i mean, it still spinning, no change on speed
Was thinking to reduce clearance between pto fingers and thrust bearing, but i see the pto disc moving like 1 mm with the tractor stoped, so not sure if needed.
Any advice?
/ PTO disengage while runing #2
When engaging the PTO I throttle down to idle, depress the clutch, engage the PTO, then bring it up to PTO speed. To disengage the PTO depress the clutch first. Not doing this can cause excessive wear on the gears and may lead to the PTO disengaging on its own. I'm not saying that's your case, just saying it's a possibility.
Well , this is how I usually use it.
DITCH WITCH TRENCHER (A65643)
DITCH WITCH...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
2012 Infiniti G37 Sport (A62613)
2012 Infiniti G37...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
