3-Point Hitch Pto disconnect
/ Pto disconnect #1
hturner12
Thomaston ga
LS Xg 3025
Brand new tractor owner. Newbie question how do I disconnect the pto?
/ Pto disconnect #2
If you mean the shaft itself, there is either a collar that you pull towards the implement while you pull the shaft off the PTO a stub. Or a button on the collar that releases the connector and again, you pull the shaft off the PTO stub.
/ Pto disconnect
Thank you
It got the collar, it on the rotary cutter
/ Pto disconnect #4
Note that not all collars will pull back to release. The one on my Bushhog brand mower has to push forward while you pull back on the PTO shaft, a not so easy task to do.
So if you cant easily remove the shaft by pulling back on the collar, try pushing it forward.
/ Pto disconnect #5
Collar type are a pain. My brush hog has one, I hate it. Even lubed up its awkward to operate. All my dad's stuff (what I've used for the past 30+ years) has a pin you push in while pulling it off the PTO shaft.
/ Pto disconnect #6
Mine has a pin you push in while pulling back on the collar. It can be a PITA if the PTO shaft is "bound up" a little. Mine is on my chipper and every so often I will open up the chipper inspection cover - rotate the chipper wheel forward/back to free up the PTO shaft. Most times it will slip right off.
I've found that the reason the PTO shaft binds - there are still small limbs/twigs in the cutting chamber that are holding the chipper wheel.
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2011 JOHN DEERE 710J BACKHOE (A65053)
2011 JOHN DEERE...
40ft High Cube Shipping Container (A64553)
40ft High Cube...
New/Unused Wolverine Hydraulic Hay Bale Squeeze (A65583)
New/Unused...
