PTO dies...
/ PTO dies... #1
3crom
middle,Alabama
1997 Cub Cadet 48" Deck
This just started twords the end of cutting my grass,I haven't blown off my deck yet of trimmings [just thought of this.:rolleyes: ] but my pto will will shut off with a hesitation or sometimes fast,I thought at 1st it might be my seat , now I'm thinking its the switch, my VERY expensive dealer has a no return on open parts policy,IF he remotely has a part I need:mad: :rolleyes: $$
I guess go the cheapest route first?? any ideas??
Dave
/ PTO dies... #2
That happened to my 2138 also. The PTO wiring had partially burned through and so it would intermittently short on the block. I replaced the harness and then wrapped it with insulation to keep it from happening again.
/ PTO dies...
:mad: I'm almost sure you can't replace the wires going into the clutch on mine.
I wish I could...because thats all thats broken is one of the wires,right at the very base going into the plastic on the clutch.
Dave
/ PTO dies... #4
If you're really determined, sometimes you can salvage a part like that. In the past I've cut open the wrapping on electric coils and fished out the broken wire, soldered a new lead on it and rewrapped the coil with electrical tape. I figure there's nothing to lose if it doesn't work.
Bob B.
2019 FORD F-350 SUPER DUTY (A65643)
2019 FORD F-350...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Unverferth Perfecta 3pt 20' Field Ciltivator (A64126)
Unverferth...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
