PTO dies...
/ PTO dies... #1
3crom
middle,Alabama
1997 Cub Cadet 48" Deck
This just started twords the end of cutting my grass,I haven't blown off my deck yet of trimmings [just thought of this.:rolleyes: ] but my pto will will shut off with a hesitation or sometimes fast,I thought at 1st it might be my seat , now I'm thinking its the switch, my VERY expensive dealer has a no return on open parts policy,IF he remotely has a part I need:mad: :rolleyes: $$
I guess go the cheapest route first?? any ideas??
Dave
/ PTO dies... #2
That happened to my 2138 also. The PTO wiring had partially burned through and so it would intermittently short on the block. I replaced the harness and then wrapped it with insulation to keep it from happening again.
/ PTO dies...
:mad: I'm almost sure you can't replace the wires going into the clutch on mine.
I wish I could...because thats all thats broken is one of the wires,right at the very base going into the plastic on the clutch.
Dave
/ PTO dies... #4
If you're really determined, sometimes you can salvage a part like that. In the past I've cut open the wrapping on electric coils and fished out the broken wire, soldered a new lead on it and rewrapped the coil with electrical tape. I figure there's nothing to lose if it doesn't work.
Bob B.
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2015 New Holland 560 Round Baler (A63688)
2015 New Holland...
1985 Ford F-250 Pickup Truck (A62613)
1985 Ford F-250...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
