Pto clutch for chinese equipment
   / Pto clutch for chinese equipment #1
chuckinNC
I have a farmpro dozer which has no hole in the pto shaft for
mounting a clutch, i can run the bushhog straight but would
rather use a over run clutch.
Has anyone run into this problem with Chinese tractors.
   / Pto clutch for chinese equipment #2
Are you talking about an Over-run coupler or a slip clutch?
I know on some of the over-run couplers that are quick disconnect and go on and off just like a typical PTO shaft. Then there are the semi permenant types that fasten on with a roll pin. The roll pin types need the hole but the other type does not.
   / Pto clutch for chinese equipment #4
Your right it does have a 2 stage clutch or live PTO, when u
push the clutch in to stop the dozer the PTO will still turn. I
like the idea of a over run clutch even with live PTO when
using a bush hog.
   / Pto clutch for chinese equipment #6
</font><font color="blue" class="small">( I like the idea )</font>
Well, it's your money.
As was stated above, you need the removeable type. It uses a spring pin that locks into the spline's circumferential groove, rather than the roll-pin design of the permanent mounts.
//greg//
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
SCAN TO RECEIVE TEXT UPDATES (A51248)
SCAN TO RECEIVE...
2025 Swict 72in Bucket Skid Steer Attachment (A51691)
2025 Swict 72in...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53473)
2019 New Holland...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
2013 Nissan Titan Ext. Cab Pickup Truck (A51692)
2013 Nissan Titan...
