Pto clutch for chinese equipment
   / Pto clutch for chinese equipment #1
chuckinNC
I have a farmpro dozer which has no hole in the pto shaft for
mounting a clutch, i can run the bushhog straight but would
rather use a over run clutch.
Has anyone run into this problem with Chinese tractors.
   / Pto clutch for chinese equipment #2
Are you talking about an Over-run coupler or a slip clutch?
I know on some of the over-run couplers that are quick disconnect and go on and off just like a typical PTO shaft. Then there are the semi permenant types that fasten on with a roll pin. The roll pin types need the hole but the other type does not.
   / Pto clutch for chinese equipment #4
Your right it does have a 2 stage clutch or live PTO, when u
push the clutch in to stop the dozer the PTO will still turn. I
like the idea of a over run clutch even with live PTO when
using a bush hog.
   / Pto clutch for chinese equipment #6
</font><font color="blue" class="small">( I like the idea )</font>
Well, it's your money.
As was stated above, you need the removeable type. It uses a spring pin that locks into the spline's circumferential groove, rather than the roll-pin design of the permanent mounts.
//greg//
Kubota L3200 (A50123)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
377789 (A51573)
377789 (A51573)
POWER BREEZER PORTABLE ELECTRIC EVAPORATIVE COOLER (A51248)
POWER BREEZER...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
2121 (A51244)
2121 (A51244)
