Pto clutch for chinese equipment
   / Pto clutch for chinese equipment #1
chuckinNC
I have a farmpro dozer which has no hole in the pto shaft for
mounting a clutch, i can run the bushhog straight but would
rather use a over run clutch.
Has anyone run into this problem with Chinese tractors.
   / Pto clutch for chinese equipment #2
Are you talking about an Over-run coupler or a slip clutch?
I know on some of the over-run couplers that are quick disconnect and go on and off just like a typical PTO shaft. Then there are the semi permenant types that fasten on with a roll pin. The roll pin types need the hole but the other type does not.
   / Pto clutch for chinese equipment #4
Your right it does have a 2 stage clutch or live PTO, when u
push the clutch in to stop the dozer the PTO will still turn. I
like the idea of a over run clutch even with live PTO when
using a bush hog.
   / Pto clutch for chinese equipment #6
</font><font color="blue" class="small">( I like the idea )</font>
Well, it's your money.
As was stated above, you need the removeable type. It uses a spring pin that locks into the spline's circumferential groove, rather than the roll-pin design of the permanent mounts.
//greg//
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
