PTO Alignment(?)
   / PTO Alignment(?) #12
If phasing is the issue (as indicated by the drawing you posted) I wonder why phasing would be important on a bottom mounted PTO, but not a rear mounted PTO? I've never seen this on a rear PTO.
- djb
Phasing is very important with ANY shaft with universal joints. Be it a baling machine, drive shaft on a truck, a PTO shaft....whatever....
Then we could get into the angling of those u-joints with some more physics.......
   / PTO Alignment(?) #13
geniousCastor, Once you get the orientation right, clean a spot on both parts and put a little dab of light colored paint on it. That'll save you a lot of aggravation. BTDT.
   / PTO Alignment(?) #14
Maybe "PTO" is not even the correct terminology.
I'm referring to the shaft that drives the belly mower. It would look like pic below if totally removed, I am just dealing with separating the splined part of the shaft:
Sorry, and thanks for the responses.
- djb
Mark the two ends with a paint stick, then line up the marks next time you need to put it back together. That's what I done on mine which looks just like yours.
   / PTO Alignment(?)
Yessir, I might try that.
Another thing I learned after getting it together this time was that the bottom PTO shaft will turn if the PTO selector (Mid/Rear/Both) is set to Rear. I didn't know that and could not get the tractor shaft to turn. More frustration. :fiery: [ <- I like this guy :laughing: ]
I wonder if unbolting the yoke might be easier yet? But if so, someone would have suggested that already...?
- djb
2021 Chevrolet Colorado Crew Cab 4WD Pickup Truck (A55852)
2021 Chevrolet...
2017 Freightliner 114SD Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55852)
2017 Freightliner...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
2021 Deere 331G (A53317)
2021 Deere 331G...
