PTO Advice needed
   / PTO Advice needed #1
Marada
Missouri
Iseki 1700F
Jeez, if it's not one thing it's another. These tractors are like boats. Anyway, I got some good advise on the Bulldog loader I have on my Iseki. Whats going on now is I had purchased a 5 ft finish mower in rough shape. I restored it and went to attach it to the tractor. The problem is the PTO coupler won't slip onto the PTO Shaft. The coupler is pretty weathered and I have a feeling its the corrosion and such. I greased everything up and it just barely starts. Any suggestions on cleaning it up? Or do I just buy a new one?
   / PTO Advice needed #2
G'day you can get small toothbrush sized wire brushes for a couple of dollars grab one and some wd and give it a good clean you will prob find after the first use it will free up. Good luck:)
Jon
   / PTO Advice needed #3
I use the Spray Carb cleaner to clean Mine up , works Pretty good at getting back in there loosining up old grease & surface rust . Followed up with a brush like Jon Mentioned. Bob
   / PTO Advice needed #4
Also.. be aware that there is a retainer ball or pin that may be sticking and not allowing you to push the coupler on past about 1/2" or so.
soundguy
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51242)
2021 HAMM HD+9I VO...
2022 30ft 20k Blazer Deck-Over Trailer (A52128)
2022 30ft 20k...
24' Free Standing Livestock Panel Swing Gate (A50515)
24' Free Standing...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
Auger Skid Steer Attachment (A50322)
Auger Skid Steer...
