PTO adapter
/ PTO adapter #1
Loges1
S.W. Missouri
Century 3045
I'm thinking about buying a 3pt sprayer but the pump is splined for 1000rpm(small splines). My tractor has a two speed pto but the shaft has the 540(big)splines. To change speeds I move a lever between 540 and 1000rpm. Does anyone know if there is an adapter that will slide on my shaft that the pump can then slide on to?
/ PTO adapter #2
I have seen several types of PTO adapters at Agri-Supply, but I don't recall exactly what they have. You'd also need to have room between the sprayer shaft end and the tractor for the adapter to fit.
I imagine Tractor Supply also carries this sort of thing.
I'd definitely make sure of the availablity to hook it up the the tractor before I committed to the purchase. /forums/images/graemlins/smile.gif
Chris
/ PTO adapter #3
Those adapters will increase the overall length of your PTO shaft by 3-6 inches. Hopefully the PTO shaft will have enough slide in it to handle that if not you might have to shorten it.
/ PTO adapter #4
If this is a PTO driven sprayer pump that sits on the PTO, the coupler is probably a separate unit. A couple set screws take it off and all thats on the pump itself is a keyed shaft. Then you can replace it with a different coupler.
Also it may be a 1000/540 dual speed coupler. I think those have unevenly spaced splines so you can look for those.
/ PTO adapter
Thanks for your help guys. The pump is a Delavan centrifugal pump that slides right on the pto shaft. There is a bracket that bolts to the drawbar to hold the pump, so I don't think the extra length will be a problem.
/ PTO adapter
Again many many thanks /forums/images/graemlins/grin.gif
2023 Kubota Z252KH-54 Zero Turn Mower (A63118)
2023 Kubota...
UNUSED KJ 45'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 45'X25'...
UNUSED ATS ACE80-80 GALLON ELEC. AIR COMPRESSOR (A62131)
UNUSED ATS...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2013 ISUZU NQR 4X2 REFRIGERATED BOX (A59909)
2013 ISUZU NQR 4X2...
2011 Ford F350 Service Truck (A63116)
2011 Ford F350...
