PT425 Wheel Motor Torque Increase - 30%
   / PT425 Wheel Motor Torque Increase - 30% #21
Think of it this way...
On a normal HST tractor, the engine turns a pump that provides hydraulic juice to ONE hydraulic motor. That motor turns a shaft that turns a gear box that has 2 or three ranges. The output shaft of that gear box turns a differential, which turns the wheels. By using your foot to vary the amount of juice that gets from the pump to the motor the speed of the motor is varied. This is done because when you push the pedal, the angle of the swash plate changes in the variable volume pump. Low angle = high torque and vice versa. Where the gear box comes in is just like gears in a car. You can have a low range with massive torque and low top speed, say 0-4MPH. A middle range with less torque and more top speed, say 0-8MPH. And a gutless high range with very little torque but very high speed, like you would want for road travel, say 0-18MPH. You can feather that high range with the softest foot all you want, but you will have no guts behind it because the gearing is too high.
On a Power Trac, the engine turns a pump that provides hydraulic juice directly to all FOUR wheel motors. There is no gear box or range selector and no differential(s). Operation with your foot is the same... low speed = high torque and vice versa.
My PT425 is listed as 0-8MPH. If they would use different wheel motors(one's with lower RPM but same hydraulic flow), I could have way more torque, but way less top speed. Good for excavating, bad for mowing the lawn. So, they had to come to a compromise between low end torque and top end speed by selecting the proper pump and motor that would give the optimum performance for MOST jobs the machine is used for. There is some torque sacrificed and some top end sacrificed in this setup.
You can let off on the pedal to give it maximum torque, but a normal tractor will have more torque in low range. You can also mash the pedal down for top speed, but a normal tractor will have more top speed in high range.
With that said, I think the Power Trac system is a very good blend of what I would compare to the low and mid ranges of a normal tractor. I really like it. There are few times I wish I had more low end torque. On a machine that weighs only 1500 pounds with operator, I lose traction before I lose power. Although this afternoon I had plenty of traction and torque... I spun the left front tire off it again. So much so that I blew it halfway off the rim, all the wire came out of the sidewall, and the inner tube was bulging all over the place. I almost made it back to the garage on the inner tube, but the wires popped the tube, so I had to go in reverse by skidding along on the bucket. New tire and tube will have to be purchased tomorrow.
How could they add two ranges to their setup? I'm not sure if I would want it, but I can think of a couple.
1. Two speed wheel motors. Although this has been discussed, I don't see how you could get all four wheel motors to be in the same 'gear' at any given time. Maybe someone could explain that.
2. Two speed pump. That would seem more logical. Log splitters use two speed pumps. High speed until enough force builds up to kick it over to low speed with massive torque. Of course, I know doodly beans about hydraulic motors, so maybe someone could explain that one as well.
3. Differentials and gear boxes. BOOOO! /forums/images/graemlins/mad.gif Nobody wants to go back to differentials. You'd need positraction or lockers and that would tear up the turf. Remember, the Power Trac never tears up the turf and we like that! /forums/images/graemlins/grin.gif
OK. Any other thoughts about how to get HI/LOW ranges out of these beasts? Do we really want HI/LOW ranges? Do we like it just the way it is? Should I convert to the new wheel motors, or is it not that big of a deal? I need to test drive one of the new ones to compare it to my green machine of 2001 and see just how much of a difference it makes. /forums/images/graemlins/wink.gif
   / PT425 Wheel Motor Torque Increase - 30% #22
I have found that as much as I like my little green PT machine it does not take the place of my 4 wheeler. Each has their definite purpose. Many times they are used together. I really wouldn’t want to choose between the two. With the coast of an upgrade one might consider picking up a good used 4 wheeler. You won’t need one with 4 wheel drive for obvious reasons. (Just some food for thought).
   / PT425 Wheel Motor Torque Increase - 30% #23
/forums/images/graemlins/smile.gif MossRoad,,,,I am quite happy with the 425 just as it is. Granted, mine is the latest version with the bigger motors. In excavating under my house I was climbing out of the hole up a slope that was close to 20 degrees (4' rise in just under 12' run) with the 10' bucket filled level. I found early on that maximum traction was achieved by backing out. With a full bucket going forward the 425 started digging holes half way up, but in reverse I was able to get out with no problem. The material underfoot was very sandy and I would occasionally wet the slope when traction started to lessen. I can't imagine needing to do any more extreme loader work than I did under my house, and the PT 425 was MAGNIFICENT !!
   / PT425 Wheel Motor Torque Increase - 30% #24
"" I lose traction before I lose power "" "" I need to test drive one of the new ones to compare ""
AYK, I have a 2/4 model (Kohler, Hi-Torque, Bar Tires). Mine will not spin a wheel! But, is that due to the Bar Tires, or the heavy clay soil?? If I try to dig into solid clay at full throtttle, the PT just stops and groans! The engine only drops a few hundred RPM. If you are working on sandy soil with Turf Tires, maybe that's how you get the wheel spin! But, if it is working for you, why change!!??!!
/forums/images/graemlins/confused.gif
   / PT425 Wheel Motor Torque Increase - 30% #25
With full loads I almost always travel in reverse. One reason is I like to go fast. I keep the bucket very low to the ground for maximum stability. If I'm going fast forward, and the tractor bounces, the bucket digs in and can stop me abruptly. Ouch! By going in reverse, the bucket is trailing and acts like a wheely bar. It skids over everything and I don't have to slow down.
   / PT425 Wheel Motor Torque Increase - 30% #26
Yes, I have all sand, all the time. Our home is on sandy loam and our property is massive sand dunes under sandy loam with some sandy muck in the sandy bottom. Sand, sand, sand. And I have turfs. They do very well, but I spin them. That's why I was surprised that I got a good bite and spun the rim inside the tire. Plenty O' torque. I think it is just the right balance for a machine this size, but still wonder what a 30% increase would do. I often look at the wheel spin as an indicator that I've reached the limit of the machine and wonder if increased torque on my unit would = increased chance of damaging something. Probably not.
<font color="blue"> But, if it is working for you, why change!!??!! </font>
Why not? /forums/images/graemlins/grin.gif
   / PT425 Wheel Motor Torque Increase - 30% #27
One of my goals when tractor shopping was to reduce the number of engines that I have to maintain and to save space in the garages. That's why the quick attach was such a great feature. Pop the implements off and on like changing gloves. I can't think of anything that I currently do with my tractor that a 4 wheeler would do better other than drive around the place faster.
But I don't have a 4 wheeler(yet /forums/images/graemlins/grin.gif), so I really can't tell. I've always thought of them as recreational vehicles. I've seen them evolving into work tools with more and more attachments available, but I don't know...
What are some of the tasks you use it for and how does the torque compare to the PT?
   / PT425 Wheel Motor Torque Increase - 30% #28
What a 4wheeler might do better that the pt.
First of all you just can’t compare a 4 wheeler to a PT.
A 4 wheeler can carry or pull something but it doesn’t lift, dig or even push.
Having a 4 wheeler helps if you have long distances to travel to do small things. I use it to carry fish feed to the ponds. The farthest is about 500 yards away the others about 100 to 200. Long bumpy ride on a pt. 4wheeler is smooth easer driving and faster even without being in a hurry. Its is much easer and safer to ride double on the 4 wheeler. Try running a loose cow down on a PT. but if you run it to death try burying it with a 4 wheeler. Each have their place.
4 wheelers can have a lot of torque but in choosing one to go with the pt it would not be a concern. I would want it to have a ball hitch and racks.
   / PT425 Wheel Motor Torque Increase - 30% #29
OK. The long distances make sense as does the two people thing. I don't have cattle, though /forums/images/graemlins/wink.gif
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2025 Swict 60in Bucket Skid Steer Attachment (A55851)
2025 Swict 60in...
30pc. 16ft.x 3ft. Grey Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55314)
2023 Kubota L3560...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2018 FREIGHTLINER...
